Setting Up Rig Question |
Wopa
New Member Joined: 03 July 2020 Status: Offline Points: 2 |
Posted: 03 July 2020 at 5:54pm |
Hey All, I've been lurking on here for a while now and im looking at building a single stack rig I've seen the Orbit 4's And really like the look I was wondering, If i was to purchase these speakers how would I setup the system with a Scoop. Am I right in saying the order goes Speaker's > AMP > Mixer > Laptop/Decks? If anyone wants to fill me in would be great, I'll link the speakers down below also! Thanks. http://www.soundgear.co.uk/orbit4.html <<< speaker link!!
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 813 |
Decks > mixer > DSP (or EQ > Crossover) > after the DSP/Crossover, you split the signal into three or four amps. Number of amps is depending on how you run those Orbit 4. They can be driven in two ways.
3way active = you need 3 amps for Orbit 4. After DSP/Crossover it goes: DSP > Sub Amp > subs. DSP > low Amp > low section of Orbit 4. DSP > mid Amp > mid section of Orbit 4. DSP > hi Amp > hi section of Orbit 4. 2way active = you need 2 amps for Orbit 4. After DSP/Crossover it goes: DSP > Sub Amp > subs. DSP > low Amp > low section of Orbit 4. DSP > mid/hi Amp > mid/hi section of Orbit 4. This setup is for a stereo rig. But in here its more common to run i mono rig (dont know why, because it sounds like ****), so if you run mono, you can do it all with two amps. Better for your wallet.. Bad for your sound. Edited by FOO - 03 July 2020 at 6:30pm |
