  New Posts New Posts RSS Feed - Shall i choose to build the punisher or not ???
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 5:23pm
Been said on here that punishers don't need kick, that's why I asked.
Next question:
Indoors or out. If indoors how many people?
It just is.
sam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sam Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 5:44pm
It will be mostly outdoors. Punishers don't need kick ??? that's definintly not what I've understood from my readings, are you sure ...
iand4403 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iand4403 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 6:03pm
Punishers crossed at 100hz sound good :)
They can also be rolled up and down stairs or lifted into a vehicle by 1 person (but if you get back ache don't blame me LOL)
Edited by iand4403 - 16 May 2010 at 6:03pm
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 6:03pm
If you want deep sub, why are you even thinking about Punishers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 6:09pm
http://www.speakerstore.nl/constructions/punisher/punisher_v4.jpg
They work well without kick.
Search some more, they really are a one bin solution if need be.
However, as Lev says....
Personally for outdoors I'd be making 1850's or similar.
It just is.
sam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sam Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 6:50pm
quote : If you want deep sub, why are you even thinking about Punishers?
quote : Personally for outdoors I'd be making 1850's or similar.
Yeah I might be going down the wrong road, i'm after deep sub for playing outside, I like the idea of a small compact yet very loud solution, and from what I hear a stack of 4 or 6 punishers will go quite low, that's why i'm interested in this box, also the Ciare driver is rather cheap.
1850's would be an easier solution maybe, but would they go as low as a nice stack of punishers ???
Perhaps I would be better off putting X1's under HD215's ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:50pm
Some say X1's throw, some not.
Age old question, sub = scoop/reflex/bandpass. Outdoors = horn. To get sub from horn, need lots to couple. IF you have the skills to build punishers then try them, sell them if you don't like.
Difficult build IMHO.
Saul has 4 x Rhino's for saleBig smile
ES18 and MT1?? on top?
It just is.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 8:02pm
Punisher + X-tro combo has most professional look and feel out of any DIY sound system. They have just soooo much thought behind them.
I've understood Punishers sound more hifi than 1850 horn and drop slightly lower too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 8:16pm
+1 on the look.
Sub is a funny word that needs to be defined. Dub style reggae or not.
I know of Dubstep nights done with 6 x USB that were fine, try that with reggae and you'll get laughed off.
It just is.
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 10:19pm
Compared to most DIY subs punishers sound great. It is a very tight controlled sound, no wallowing muddy noise or one note honkiness. I have used them for every style of music I can name, including dubstep, drum & bass etc, and they faithfully reproduce whatever you put in. They may not play as low as some designs but as has been discussed on here many times before most music, even bass heavy music, has little content below 40hz, certainly nothing that the punters will miss if it's not there.
They are also a very neat package, small enough to handle easily, use a fairly cheap driver and are very efficient. They also take quite a lot of power if you have it available, but don't think you have to put the 1200 watts some people use into them, they still sound great with much less. The high efficiency could be very useful if you're doing free parties and don't have much mains available or are using generators.
Blahblahblah
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 11:09pm
You're even persuading me now, mmm, more wood ;)
So can they go to 120hz OK?
It just is.
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 11:50pm
Id say 50 - 100Hz is the ideal low pass point, though i know some people run them higher,i think they go plenty low enough for dubstep and dnb, not quite as low as scoops but they sound tons better than any scoop ive ever heard, i dont think HDs are the best choice above punishers, i have both but and you can get them sounding good together, but your wasteing usable bandwidth on both cabs, the xtro kick section is better optomised to run above punishers.
