  New Posts New Posts RSS Feed - Shall i choose to build the punisher or not ???
 Post Reply Post Reply Page  <1 234
iand4403 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iand4403 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:08pm
You wont be disappointed Thumbs Up
VPAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VPAS Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:31pm
+1
Make sure you get a BIG amp for them. We ran ours for about a year off a camco v6, we were happy with them then but after hanging them off a 5000vz....
n^2 modulo -P = number wang
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:41pm
Hello,
I really agree with VPAS, having the right amp makes a big difference! Also 'watts' do not say everything. In practice some amps are just more bass heavey. I have also good experience with  QSC PL6.0/9.0, MC2 E45 and also FFA do very well on Punishers.
Best regards,
Walt
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:19pm
Compact yes, but the X-tro, is that not a heavy sod, so you gain on the subs weight but die lifting the X-tro?
It just is.
Sinfinity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinfinity Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:35pm
Xtro's not that bad to lift at all. I can lift one on top of a pair of stacked bins ( about five foot from the floor ) without too much difficulty. With two people it becomes real easy.
Matt at ukamp dot co dot uk
Louder than loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louder than loud Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:17pm
Originally posted by sam sam wrote:
It will be mostly outdoors. Punishers don't need kick ??? that's definintly not what I've understood from my readings, are you sure ...
That's right they don't need any kick, i've heard & used 2 a side upto 8 a side and there fine crossing over at 125hz.
Also why are you going for a 3 or 4 way system ? more amps, more cable, need better crossovers, more space, more money LOL
A simple twin 18" and passive midtop something like a 15" & 1.5" is great
Sibulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sibulus Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 5:08pm
Highly sceptical, to say the least, about that mate.  I found even taking them upto 110hz resulted in a muddying of the sound. I have never heard of, nor seen, anyone running them as an all in one bass solution - x-tros, HDs, always some form of ''kick'' cab on top. What sort of cab were you running above them, if you don't mind me asking.
http://soundcloud.com/judas-beast
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louder than loud Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 12:05am
A bi-amped midtop again loaded with a 15" & 1.5"
LR48 30hz - 110hz LR24
LR24 110hz - 1.2kHz LR24
LR24 1.2kHz out LR24
Edited by Louder than loud - 08 June 2010 at 1:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 8:53am
Happy to be corrected, I was more or less quoting what someone else said on here, can't find it now though, maybe I got confused but I thought someone said thy are a, "one box bass soluion"...
It just is.
sam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sam Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 11:23am
Ok I think maybe I've been abit too ambitious ... after further documentation I've realised that 6/8 punishers is going to cost quite alot to power, and funds are limited so I'm now more thinking of starting with 4x 1850 horns loaded with void v18 1000 + 2x MT121 or MT122.
Would MT121 be good or should I go for MT122 (more complicated and more expensive Cry)
What do you think of this overall system ? To me it seems easier to build, less money and I beleive will deliver alot of quality sound anyhow. Bear in mind : outdoors/jungle/dubstep/tekno ...
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 12:39pm
go for it. thats what im building very soon! im going for the mt122. and i would suggest you do the same. and im putting pd1850 in the 1850horn.
it only took me a few years to deside what i wanted to build but hey got there in the end. LOL
im sure it will cover all your music type pretty dam well.
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2010 at 12:49am
just built some 1850s for a mate i know its northing todo with the punisher, but we ran these out side and in the living room. inside or out they sounded awsome and the living room wasnt that big!
acoustics ay what a bitch
