Should i have wadding in my hd15's |
tcourtneyvincent ![]() Young Croc ![]() Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
![]() ![]() ![]() ![]() ![]() Posted: 12 February 2013 at 1:55pm |
Like the titles says, what material should i use if so and how much.
Thanks |
njw ![]() Old Croc ![]() ![]() Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2529 |
I haven't got any in mine and I'm happy enough with how they sound, I can't actually see wadding making much difference in a HD anyway with the size/shape of the rear chamber how it is.
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
I used dense foam (the egg box sort of dimpled stuff) in the rear chamber, and found it removed a lot of the higher frequency box resonances (is how I would describe the noise anyway!).
Easiest thing is to get some wadding and lay it round the inside of one cab, and A/B with one without the wadding. If you like it, staple the wadding in place and do the rest of the boxes. |
hulkeh ![]() Registered User ![]() ![]() Joined: 12 July 2011 Status: Offline Points: 80 |
That what i used in mine Norty and im happy with the results :)
nuclearbass ![]() Old Croc ![]() ![]() Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
i have ab'd them before i put some in mine and i feel it gives a better sound...
one life - have fun!
Force fusion pro audio |
I ended up stapling in roughly .75cm deep carpet into mine and they sound much better to my ears, defo a little drop in spl but well worth the warmer thud.
tamuks ![]() Registered User ![]() Joined: 16 April 2012 Location: zimbabwe Status: Offline Points: 232 |
nearly all closed enclosures must be warded for them to give good sq
K.A.S.S the art of digital sound entertainment
