Page <1 5758596061 690> |
mykey- ![]() Old Croc ![]() ![]() Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6109 |
![]() imagine untying that and not not notifying anyone in front of it ![]() ![]() |
Combe ![]() Registered User ![]() Joined: 19 January 2010 Location: Nantes, France Status: Offline Points: 48 |
My main system : 2 Nexo PS15R2 + 2 Nexo RS15 ![]() Powered with that : 2 Crown I-Tech 8000 + Nexo PS15R2 TD Controller ![]() Also have smaller systems (Nexo PS8 & PS10), but no photos.
discosucks ![]() Old Croc ![]() Joined: 06 November 2009 Status: Offline Points: 1539 |
haha plenty of head room anyways,
lovly wee amp rack dude |
Phil B ![]() Old Croc ![]() Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2144 |
Not mine but from work....
Big EV X-Line system for this weekend... This is what 112 x P3000 ( 28 x 4 way amp racks) looks like with Littl` Ben standing in the middle of the P3000 sauna ( it was well hot with all those turned on!) ![]() And a side view of under half the amps....with our Head of Digital trying to make it all talk to the main computer rack! ![]() So if each P3000 does 2500 a side at 4 ohms.....thats what 560,000 watts looks like! Very very silly ! .p. |
Solar & Wind Sound System Shennanigans..http://diyhifi.biz/ |
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: BURNHAM ON SEA Status: Offline Points: 2962 |
some serious weight there in both ways...........
![]() Edited by paulus - 10 September 2010 at 2:17pm |
TRENDSETTER SOUND SYSTEM
Nigey-C ![]() Registered User ![]() Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
im sure they only do 1800w @ 2ohm per channel?? or ive read the wrong manual..? could be wrong. |
4D ![]() Old Croc ![]() Joined: 13 November 2008 Location: Winchester Status: Offline Points: 3839 |
![]() This is what 8 Ass sb121h and 6 martin waveform can do to a vocalist.. |
Well it's only a stupid example wattage figure ! Seeing as some will be running tops and mods I doubt it'll be that much current drawn. Still it's a lot of amps in one place. P |
AUDIO HABIT ![]() Old Croc ![]() Joined: 15 June 2009 Location: Manchester Status: Offline Points: 3382 |
blimey... what a top job you have got ..what i would do to work in a place like that
Bad Man Moriarty ![]() Registered User ![]() Joined: 05 February 2009 Status: Offline Points: 275 |
he looks like he is heading straight for that guys fist |
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7262 |
He is not jumping. He is hanging from the ceiling. LOL
MattStolton ![]() Old Croc ![]() ![]() Joined: 04 September 2010 Location: Walthamstow Status: Offline Points: 3969 |
Here is my 2p worth, and it may be all its worth Any way, my home system, for listening to nasty mp3s, Mr Andrews will be wagging his finger at me as I type: The speakers are "reworked" Wharfdale Linton 3XPs, famous because the mid driver was the first to be designed using a computer!! The mids are the original drivers and don't sound too bad. The bass/low mids are model 2065T, with two facing each other, the outside one wired in opposite phase, to the internal one. Ebay special of £20 for 4. Quite cute 1" wharfdale silk domes finish off. (I am not a fan of wharfdale, nor work for them, it just seemed to all come together, but seemed right as the original box is a "heritage" model) My little amp rack is equally budget and ebay. The anytronics 2x150W drives the four bass drivers, HPF 40Hz-LPF 300Hz. The 3U box is my own build/bastardisation of a Rogers A100 integrated amp (about 2x50W) driving the mids, about 318Hz->4KHz. The other 2 channels of amp in the 3U are Maplin bi-polar amp kits, again 2x50W. My 3U amp has 20000uF in each of the 4 supply rails! The Xover appears to be a chinese version of the Ohm Cleo mkII. Given its age, I'm not sure who got it out first, Ohm or a chinese factory, but either way suits my purpose. All fed from a Soundblaster external sound card, although I'm hoping to get an edirol DA2496, to eliminate USb bus noise. My attempts to measure on ARTA can not be taken as gospel, but my ears seem to agree, and its flat enough from 50Hz to 17Khz to pass my mustard test. The only thing I don't like, is they didn't make handed cabs, so the mids are both right, HF both left, but a little time correction in the Cleo has solved that!! Anyway, before you all start sniggering, it was a fun home project, and cost less than £150 all in. I am a proper sound engineer, i promise, here is something from my day job: Fully battery backed up, with a fibre optic link to a second pair of 47U racks in the other side of the bus station, this is the Voice Alarm Master Rack I fitted to Finsbury Park Bus Station! |
