  New Posts New Posts RSS Feed - -=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 3
 Post Reply Post Reply Page  <1 7778798081 95>
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2020 at 10:12pm
''The Phoenix Rises''
Jah youth lost all his sound system, and wasn't insured, in a storage fire and had to start from scratch Cry
He picked this up today, and also the Hackney gazzette did a piece on him
Edited by KidCreole - 08 August 2020 at 10:14pm
Mykey Wattco
Bams View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bams Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 1:23pm
If this rig only sounds half as good as it looks it is already awesome. great to see something different.
Sypa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 3:03pm
I Like the color but the lettering/logo of the boxes could be better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 5:42pm
Thanks. Sounds much better than it looks. It took Jah youth 3 seconds to make up his mind when the subs came on
Mykey Wattco
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 5:44pm
The colours and font was down to the client
Different fonts and many different colours
Mykey Wattco
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 5:55pm
Mykey Wattco
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 6:00pm
Mykey Wattco
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2020 at 7:31pm
Thumbs Up
fat_brstd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2020 at 1:26am
Anyone got any idea what is going on with those kick bins, the 215B? The circle in the front makes the perspective really odd in those pic, looks like a curved grill behind it but no indication of how the box is loaded.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2020 at 5:11am
Been putting lock down to good use with my wife finishing the new Housewife's Choice Sound System who are the first all-female DIY Sound in Australia and as far as we can work out 1 of 4 or 5 all-female sound systems in the southern hemisphere. All up it took 2 years of designing, planning and sourcing parts followed by 13 months of cutting, routing, screwing and gluing to get to where it is at now. Still needs grills and stain/paint/varnish but it is all working and making sound so thought we would share with you guys.
The system is 5 way (4 way active, passive crossover for the Co-Ax comps):
Tops - BMS 4590-8 with C8-8 passive crossover on BMS 2236 horns
Mids - Sealed box with Eminence EC-25 (to be replaced by B&C 12NLD76 when we can get some)
Kick – Reflex box with Oberton 15B450 ported to 75hz, models as 101db 1w/1m
Sub – Rear Loaded Horn with Void V-1000
Pioneer DJM900NXS2
Allen & Heath MixWizard3 16:2
DCX2496
QSC GXD4 – Tops Amp
QSC GXD8 – Mids Amp
QSC GXD8 – Kicks Amp
QSC PL380 – Sub Amp
4 channels of compression into graphic EQ for mic inputs
Here are some videos showing the progression of the build
Finished set up – https://www.facebook.com/feebourne/videos/vb.595987717/10158878000177718
Testing the speaker distro built into the scoops before assembly – https://www.facebook.com/feebourne/videos/vb.595987717/10158364280577718
First boxes done - https://www.facebook.com/feebourne/videos/vb.595987717/10157515888247718
Anyway onto some build pics, not got heaps from the actual assembly as forgot to take pictures along the way but here goes. Main panel cuts were done using a table saw (thanks to Phil Dekked from DIY for letting us use the saw at his work), the rest of it was done with a cheap circular saw and a router. All boxes are fully rebated, glued and screwed using polyurethane glue.
Dry assembly of the mids
Soldering NL4 connectors on the mids
Handle Template
Assembled Mid Box
Kick Bin Assembly
Assembled Kick Bin
Wood cut for the Scoops
Test Assembly before cutting rebates
Marking Scoops back panels for wiring
Fitting & Securing T-Nuts for the Wheels
Side panels of scoops rebated & holes for connectors cut
Scoops coming together
Finishing Scoop # 3
4 Scoops ready for sanding
Scoops ready to load, all handles cut & all wiring complete
Comp driver horns got damaged in transit
Had to fix with a bit of Fiberglass resin
Boxes for the tops (Driver bracing missing from this pic)
Back of top boxes
Front of House Rack
Amp Rack – on left you have Left, Right & Mono in, on right you have Left & Right out on NL8
Back of Amp Rack
The Stack
The horn that got damaged is on the right, came up pretty good for a DIY repair
Side Angle view
Back of the stack to show the cable distribution. The subs have 2 x NL8 full range in/out and then Sub in/out on NL4 & Kick, Mid & Top outs on NL4. All NL4 is wired to Pins +/-1, the 2nd set of pins are not in use. Means you can run the entire rig on either NL8 or NL4/2 if need be if say you had to use a different amp rack but for 99% of work there will only be 2 cables from amp rack to stack. Subs & kick are in mono fed off the mono master fader on the MixWizard. Mids & Tops are in stereo and fed off the stereo master faders on the MixWizard
More of the cabling
Miss Fee at the controls ready for testing
Hope you enjoyed the journey, plenty more work to go to get it fully finished but at least it is making noise now.
Edited by fat_brstd - 11 August 2020 at 6:16am
facebook page
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2020 at 9:14am
Nice build. Very neat!   Smile Thumbs Up Smile
What colour/s are you going to paint them?  LOL LOL LOL
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2020 at 11:33am
Im thinking dual 15 horn. Maybe HD215ish.
