  New Posts New Posts RSS Feed - -=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 3
 Post Reply Post Reply Page  <1 697071
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 4:18pm
@Tonskulus - Very nice project, interesting 4" drivers, what are they?
Only possible minor issue, the "steel" screw in the round inductor, may work like an iron core? Or is the inductor former actually "iron" anyway, rather than the dark plastic that it looks like? Perhaps use a nylon nut/bolt with hot glue to retain it?
You mention it is a prototype, and I don't know if it would actually have an audible effect, but might do?
Apart from that, looks rather fun!
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 11:47pm
Looks like a nice little system.
I agree with Matt's comment on the crossovers. The steel screw will increase the inductance of that coil. It really should be replaced with a brass woodscrew - they are readily available.
I presume the resistors are hot-glued to the panel. Depending on how much power you are using, they may may get hot enough to melt the glue and fall off. So it may be a good idea to find some solder tags, screw them to the panel, and use them as tie points for the connections.
HTH
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2019 at 4:21pm
Thank you! Yes, I know steel screws are absolutely no no when it comes to crossover coils.  This particular coil is ferrite core -type, final assembly will be without screws.  Resistors are just fine @ hot glued, they will never get even warm at the power levels used.
Audyn capacitors do what they are supposed to do, as well as almost any standard polypropylene/film capacitors. Not much audible difference if at all.  Almost any film/foil cap is just fine, bipolar electrolytics not so good as they get lossy at high frequencies, did some measurements/comparsion.
Yesterday I fired up my hogs again just for fun, had to test my Bose entero 4400 amp (4ch, 2x900wrms/8ohm bridged) which is actually really good for sub duty, as it is! Much more aggressive and precise than some of my old QSC amps.   Absolutely dangerous stuff in living room!
Edited by Tonskulus - 10 February 2019 at 4:44pm
Futendra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Futendra Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2019 at 6:49pm
A collaboration between Shikoba Soundsystem and Onkruit Soundsystem!
Six labhorns on dub duty for once :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2019 at 9:57am
Carage day
Edited by Tonskulus - 03 March 2019 at 10:03am
IncognitoSounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IncognitoSounds Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2019 at 11:40am
Incognito Soundsystem:
2 x Mini scoops built by Fracture_Clinic loaded with Void V18-1000
2 x15" reflex cabinets built by myself loaded with Fane Colossus Prime 15XS (Fane 15" reflex plans).
2 X Cerwin Vega V152 tops with Beyma 15" drivers.
First things we have ever built. Built using knowledge from Speakerplans, grills from Markie, powder coated locally.
Powered by:
DBMark XCA 2in 8out
PKNXD4000 - Tops 8r per channel
Behringer NX6000 - Kicks 8r per channel
2 x QSC RMX 2450 - each bridged 8r, 1 for each scoop.
She kicks like a mule and sounds really nice... Thank you for your collective wisdom!
Edited by IncognitoSounds - 19 March 2019 at 1:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2019 at 12:13am
Little bit of fun today...
Edited by toastyghost - 20 March 2019 at 12:15am
