-=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 3 |
Post Reply | Page <1 8081828384 95> |
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
Woodwork, grills and cables all done, system is up and running and sounding good. Just needs final sand and paint/stain (I know the crossbracing is not perfectly lined up, it is not glued in yet as waiting until the inside of the horn is painted/stained)
And the cable management system |
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
Tidy!
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
Wow that cable managment tickles me in the right place :)
imageoven
'Toto, I don't think we're in the ghetto anymore' A nice no-compromise approach to the cabinet connector set up. I think there are 22 redundant connectors on the stack, which will have been a decent amount of extra work and expense compared to fitting the absolute minimum required, but it will be worth it for the ease and speed of set up, you'll never have to re-stack the rig because it only works in one configuration.
njw
Top work! I also run an 8 way speakon to a sub cabinet and link out to the kicks, mids and tops, however, I've only fitted the extra connectors to one pair of subs so have to make sure there is one in each stack when setting up.
What colour is the rig going?
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 815 |
I dont get the idea of all those conmectors. Why not just use 8way speakon all the way? Two in each enclosure. Job done.
madboffin
Old Croc Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1538 |
Looks like a nice job.
It allows a choice of how many boxes are paralleled on amp channels, more flexibility if you need to turn down, or separately drive, elements of the stack (infills perhaps) and generally makes things very flexible. A bit like how we used to run Martin F2 stacks. You might consider rounding off the edges of those connector recesses, otherwise you will be forever cursing as you graze your fingers on the woodwork... Edited by madboffin - 13 November 2020 at 7:59pm |
FOO
Still cant see the advantage I run 2x dual 18" on each channel of a LAB PLM20K44. If flexibility is needed with more subs, a second Amp is hooked up. Same as with mains (dual 12"+comp). Infills are run of a separate amp. One cable on each stack. Always stereo setup with dual stacks.
jacethebase
Current PAT test Hifi
www.stage2sound.com |
fat_brstd
So the whole point of the multiple connectors on this rig is ease of set up. There is a dedicated amp rack that has been built which has everything connected to a patch panel so it is really easy to plug in. We went with NL4 in/out on every box as the amp rack and cable set up for my rig is all 2 core on NL4, that way if we ever need to we can use my cable for her rig. I don't like the new square NL8 connectors, much prefer the old round ones which we managed to salvage 8 of (thanks Phil Dekked) and the NL4MPR were cheap so the connectors didn't actually cost much to sort out. Buying lots of nl8 plugs & sockets would have cost a fortune and then the rig would only work with nl8 cable. Trying to do something a bit different with this one to keep it simple but also able to integrate with other setups should that ever have to happen. She has 2 more compression driver boxes so can do 4 separate stacks if need be and has 2 x 15m + 2 x 10m nl8 cables with the little neutrik link connector things so they can be combined however is required.
They are all rounded off, I think the combination of my crappy phone camera & the filter mad them look like that. Here is a slightly clearer shot. |
Futendra
Registered User Joined: 28 April 2016 Location: Belgium Status: Offline Points: 276 |
Our new setup
Labhorns, USBs and Floodlights Edited by Futendra - 22 January 2021 at 4:23pm |
munkey
Registered User Joined: 17 August 2011 Status: Offline Points: 300 |
Nice
the midtops!
