-=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 3 |
Post Reply | Page <1234 95> |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
bee
4 x double 21" quakes
2 x BSW-K215's 4 x mid highs All designed and built by myself... please note one of the middle hf horns was not turned on.
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
HF stacked vertical + physical time alignment
Sapro2
Registered User Joined: 31 January 2015 Location: Somerset Status: Offline Points: 354 |
Thanks(1)
You always have lovely locations for your venues B grade. Do the mid horns reach high enough to meet your tweeters? |
Splat Soundsystem
Baby Sham pram Soundsystem Sapro - SoundCloud https://soundcloud.com/sapro DJ Sapro. West country free party DJ and Producer. |
all bass
Thanks(1)
Looking great! No job for the reflex subs this time?
Oregon is the most beautiful place on earth. (when it's not raining )
b grade
Young Croc Joined: 05 October 2012 Location: Portland OR USA Status: Offline Points: 1337 |
The tweeter boxes are actually a slightly larger range than you would think. My lo-fi(nance) solution was to make a 2way passive crossover box. The dual horns are the same but the drivers are different. The lower horn has a more vocal mid comp on it and that can technically go lower than the horn, but not as efficient as the hf comp. Still it bridges the gap pretty well without costing ridiculous money. Obviously I would prefer to have less crossovers. I can run the tweeter boxes as low as 800 hz before it starts sounding horrid, but I usually run them at about 1.2khz. The passive crossover between the comp drivers is at 4.5khz I think. Thanks for the kind words about the spot. This one was extra special, and found at the very last minute too. I almost did this party in my basement. LOL. My first time running two different rigs at the same party. My B system was fun too, but I forgot to take any pictures. That one was for a super low extension chill room. The one in the picture was for loudness, with a retro 90s goa theme. Free and illegal for authenticity.
b grade
Hi all bass! Hope you are well. Second stage had the BP6s. I could only fit two in the van, but they were singing all night. On each side, above those I had a single 15, and then a coaxial mid top. It was for a small covered chill area, about 30 meters inside the tree-line. No soundbleed at all, and the stages were probably less than 100 meters apart. I love trees.
Bams
Young Croc Joined: 08 April 2009 Status: Offline Points: 622 |
This weekend was the Zundert flower parade. I had some involvement in two floats. first one used EV RX, other one used Sound projects X-act with subs. both used dedicated soundscapes, the last one blowing winds, supported by fans.. lots of fans.. first one used madrix for pixelmapping and loads of broken 15"and 18"speakers for the looks of much gear. winning float used D&B Q7 |
el chupacabra
Young Croc Joined: 02 August 2006 Location: United Kingdom Status: Offline Points: 757 |
This last weekend had nearly everything out in one go at Common Ground Festival.
Community TFR 34a x4, 6x Faital XL1600 loaded TH1819 tapped horn & all run from powersoft with Community oem Xilica DSP. Logic LM12 wedges with EAW JF100 & Void Mycro Bass 4 x Community SLS920, 6x RCF LF18N401 loaded USB2 Run from PLX3602 and SAE PXM 1450 Community M12 monitors with another Eaw JF100 and a beyma loaded 2x12" reflex sub for drum mons. SiEx1 Mixer. And 2x Community SLS920 with the most recent pair of tapped horns, still unpainted. Powered by Matrix XT800 and XT7000MF. First time out for four TH1819 back in April with the tapped horns as sub under USB2. |
rish
Young Croc Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Very nice El. how do those tapped horns perform? Rish
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
Managed to get out almost all of the sound the other week in Bristol
Another mid-top is in the warehouse, and another 4 scoops being built at the minute... |
Dub Specialist Sound
nice!
