  New Posts New Posts RSS Feed - -=SHOW OFF YOUR SOUND SYSTEM!!!!=-PART 3
 Post Reply Post Reply Page  <1234 95>
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2016 at 11:06pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2016 at 11:08pm
4 x double 21" quakes
2 x BSW-K215's
4 x mid highs
All designed and built by myself... please note one of the middle hf horns was not turned on.
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2016 at 6:41am
Originally posted by b grade b grade wrote:
HF stacked vertical + physical time alignment Thumbs Up
Sapro2 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2016 at 10:36am
You always have lovely locations for your venues B grade. Do the mid horns reach high enough to meet your tweeters?
Splat Soundsystem
Baby Sham pram Soundsystem
Sapro - SoundCloud
https://soundcloud.com/sapro
DJ Sapro. West country free party DJ and Producer.
all bass View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2016 at 11:36am
Looking great!
No job for the reflex subs this time?
Oregon is the most beautiful place on earth. (when it's not raining Wink)
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2016 at 2:10pm
The tweeter boxes are actually a slightly larger range than you would think. My lo-fi(nance) solution was to make a 2way passive crossover box. The dual horns are the same but the drivers are different. The lower horn has a more vocal mid comp on it and that can technically go lower than the horn, but not as efficient as the hf comp. Still it bridges the gap pretty well without costing ridiculous money. Obviously I would prefer to have less crossovers. I can run the tweeter boxes as low as 800 hz before it starts sounding horrid, but I usually run them at about 1.2khz. The passive crossover between the comp drivers is at 4.5khz I think.
Thanks for the kind words about the spot. This one was extra special, and found at the very last minute too. I almost did this party in my basement. LOL. My first time running two different rigs at the same party. My B system was fun too, but I forgot to take any pictures. That one was for a super low extension chill room. The one in the picture was for loudness, with a retro 90s goa theme. Free and illegal for authenticity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2016 at 2:22pm
Originally posted by all bass all bass wrote:
Looking great!
Hi all bass! Hope you are well.
Second stage had the BP6s. I could only fit two in the van, but they were singing all night. On each side, above those I had a single 15, and then a coaxial mid top. It was for a small covered chill area, about 30 meters inside the tree-line. No soundbleed at all, and the stages were probably less than 100 meters apart. I love trees.
Bams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bams Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2016 at 8:18pm
This weekend was the Zundert flower parade. I had some involvement in two floats. first one used EV RX, other one used Sound projects X-act with subs.
both used dedicated soundscapes, the last one blowing winds, supported by fans.. lots of fans.. first one used madrix for pixelmapping and loads of broken 15"and 18"speakers  for the looks of much gear.
winning float used D&B Q7
el chupacabra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote el chupacabra Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2016 at 7:34am
This last weekend had nearly everything out in one go at Common Ground Festival.
Community TFR 34a x4, 6x Faital XL1600 loaded TH1819 tapped horn & all run from powersoft with Community oem Xilica DSP.
Logic LM12 wedges with EAW JF100 & Void Mycro Bass
4 x Community SLS920, 6x RCF LF18N401 loaded USB2
Run from PLX3602 and SAE PXM 1450
Community M12 monitors with another Eaw JF100 and a beyma loaded 2x12" reflex sub for drum mons.
SiEx1 Mixer.
And 2x Community SLS920 with the most recent pair of tapped horns, still unpainted.
Powered by Matrix XT800 and XT7000MF.
First time out for four TH1819 back in April with the tapped horns as sub under USB2.
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2016 at 9:29am
Very nice El. how do those tapped horns perform?
Rish
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2016 at 6:12pm
Managed to get out almost all of the sound the other week in Bristol
Another mid-top is in the warehouse, and another 4 scoops being built at the minute...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2016 at 9:12pm
nice!
This page was generated in 0.096 seconds.
