  New Posts New Posts RSS Feed - Show us your Distro..
 Post Reply Post Reply Page  <12345>
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2014 at 4:46am
Nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2014 at 11:03am
Well protected! Big smile
Shaun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaun Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2014 at 7:00am
Originally posted by MAXWELL MAXWELL wrote:
I officially have distro envy
MAXWELL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAXWELL Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2014 at 10:40am
soon take away from the factory, the housing under * Power Snakes* here are ...
When it was over, it was found in the case, lay the photo ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAXWELL Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2014 at 10:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shaun Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2014 at 3:29pm
Here is one i built a while ago (sorry started) had to rush to get it operational for a gig and have not had time to revisit and complete, will be rewired next month for 3 phase operation
front view
rear view
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2014 at 3:51pm
i don't get that - you have a 32/3 coming in, yet only three breakers going to 9x 16A outlets. The only way this can be wired safely, is if each phase is limited to 16A, but then it is pointless having 32A inlet.... Also, i was sure that PVC cable isn't rated for 'mobile' use like this?
Dreadlocks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreadlocks Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2014 at 5:25pm
Im interested in a 63 amp 3 Phase Distro if anyone has one for sale
Its Not About Having Everything Thing You Want,
Its About Wanting Everything You Have
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2014 at 5:29pm
"The only way this can be wired safely, is if each phase is limited to 16A, but then it is pointless having 32A inlet"
Not if you only need 48A but spread across 9 different places and the outlet in your venue is 32/3.
Not sure how you can tell what the cable is made of! (I don't think I've ever seen 5 core cable in white, maybe it's 3 core wired to one phase only....)
With regard to 'mobile'  BS7909 7.3.3 says indoor = H05RN-F, outdoor = H07RN-F (or equivelant).
Edited by imageoven - 02 April 2014 at 5:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAXWELL Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2014 at 12:42am
SmileУважаемые коллеги ,что касается провода,то это провод 5х4 ПВХ с 3 классом гибкости,вполне годится для мобильного использования,твердеет только при отрицательной температуре..автомат расчитан на 3 фазы по 32А (по 3 розетки    по 16А,так как я делаю это для себя,то  интуитивно не перегружу их )))
SmileDear colleagues, as regards wire it with PVC cable 5x4 3 class flexibility, it is suitable for mobile use, only solidifies at temperatures below freezing .. machine accommodates 3 ​​phase 32A (3 sockets for 16A, as I do it for myself, intuitively overloading them)))
Lad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lad Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2014 at 7:10pm
Rack distro and prototype panel, which I'm not sure if I finish it sometimes
with regards, Ladislav
