  New Posts New Posts RSS Feed - Show us your Distro..
 Post Reply Post Reply Page  <1 2345>
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2014 at 9:05pm
Looks tidy. I'd want the IEC's on the inside of the rack though.
MAXWELL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAXWELL Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2014 at 9:49pm
Lad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lad Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2014 at 10:21am
You can rotate the rack ears as you want. I have designed also vertical brackets, but never got manufactured them, so it ended with bodge job. It's also possible to mount power in from opposite side to IECs. I made also version for small racks.
Edited by Lad - 14 July 2014 at 10:22am
with regards, Ladislav
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAXWELL Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2015 at 7:11pm
Finally finished assembling distributor! All completely made himself, designed by yourself!
Edited by MAXWELL - 20 January 2015 at 8:34pm
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2020 at 9:02pm
Started the distro today, drilled all the holes by hand with a drill took the micheal.
Did not see the point putting rcd on the unit and wasting space when alot of venues have them in the consumer unit and if the venue does not have them we will use a box next to the supply which will protect the cables aswell.
Will have a metal plate dividing the Hv and Lv when in a enclosure.
This can be driven one 32a single phase which disconnnects the live and neutral on the other two inputs, or can be used with three inputs if venues only have 13a plug points allk switched from a 24 terminal switch.
Also added a smart meter which measures everything and will be run from a ethernet bus so we can monitor everything to do with the mains.
The ethernet ports will be for dante and networking to the wifi router which will be powered from a 48v poe injector thats is what the small rocker switch is for.
on the rear of the unit will be four powercons and 5 iec connectors 8 nl4 and the audio signal side connects straight to the dsp via sheilded cat 5.
Everything is fused down and contains 12 fuses the internal wiring will be 6mm for Hv and speaker wiring.
Jamie Resonant Sounds.
Edited by hmaudio - 12 June 2020 at 9:04pm
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2021 at 11:10am
this has come up for sale locally for sensible money. I currently have a 2U 32A distro in my amp rack with digital metering which shows my system can pull well over 32A. This would let me run main rack off 32A d-curve and all outboard and lights off 16A supplies. Worthwhile upgrade or should I go to 63A 3-phase?
Unit looks very tidy and from reputable company. Hasn't been PAT tested since 2015 but they said if it fails when I get it tested they will accept a return. Anything obviously wrong?
Image 1 - Power distro 63a Single Phase rack
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 10:02am
I've got one of these. Not used it yet, but was cracking value. Came from the MCL Auction.
Edited by jacethebase - 21 May 2021 at 10:03am
James Tengo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 2:29pm
Nothing obviously wrong, good quality walther sockets, good breakers, nice metering, the global 30mA trip keeps you in the regs, however it is the first thing I would upgrade. The major issue I would have with it is the lack of 63a single phase outlets in venues! As a lampy - unless in TV/Film world - we avoid single phase larger than 32a like the plague. A 32a/3ph gives you 96a possible draw from a cable half the size and weight of a 63a single phase, plus 32a/3 is far more common in the venues we visit. We streamlined our heavy mains to avoid 63/1 and 125/1, but since the pandemic have been doing a lot more film & TV work where BAC, 125/1 and 63/1 is still in heavy use.  The TV boys roll up with a multiple distros breaking down BAC to multiple single phase boxes, from which they take soca to lights, it takes them ages to cable it all up... I'd rather drop in a 72way socca distro and crack on!
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 5:02pm
Their unions will oppose every change that might cut hours
or manning.
It's most likely a 3 or 4 man job their way; you can almost
certainly do it on your own Confused
I still have most of it left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 8:29pm
More to do with the use of 20k’s and 10k’s and the distro historically required for high draw applications than union rules. Older gaffers are still spec-ing jobs, so spec what they know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 3:57pm
the neutral-earth is on the amber bulb, whereas my other distro has neutral-earth across the red bulb. would be better to change both to be the same to avoid confusion. I would have thought across the red is the more usual (red=fault)
To be totally consistent I would change the indicator lights on each output to amber so that all the amber lights indicate voltage across live-neutral, and there should not be any red lights on the front panel.
Edited by snowflake - 26 May 2021 at 6:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 2:41pm
glad I opened it up - one of the fixings for the large current-sensing coil is snapped so only attached by one bolt and free to wobble about. Some bolts need some loctite on them. I've seen neater wiring!
Edited by snowflake - 26 May 2021 at 2:42pm
