Sinbosen class TD |
Post Reply | Page 12> |
Author | |||
snowflake
Posted: 06 October 2021 at 1:03pm |
thoughts on these?
Sinbosen DSP20000Q 2200w 4 channel class D DSP power amplifier (sinbosenaudio.com) Edited by snowflake - 06 October 2021 at 1:04pm |
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Not 2r stable, hence useless over here by the majority.
APW
They list 4R bridged power as 2x15000Watts RMS, this would suggest it IS 2 ohms stable. |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 816 |
LAB Gruppen knock-off
Esc4pe
Registered User Joined: 08 August 2021 Location: England Status: Offline Points: 165 |
The majority of people run 2ohm loads!?
FOO
Most of the time we run two dual 18 each side. So yes, 2 ohm.
Sometimes even three dual 18 each side. All hooked up to one LAB FP14000 running 1,33ohm on both channels. If we need four subs each side, we roll out a LAB PLM 20K44 and run 2 ohm on all four channels. |
APW
.... No the majority don't but its always nice that the amp can.
taurusty
Wouldnt trust it. The CVR clones they make are 2r stable tho... |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
CVR clones? CVR does not make their own amps. They just put a different front on them.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
Untrue, CVR make there own amps, you had the factory tour ? |
smitske96
I did not. The only thing i hear about cvr is that they do not make their own amps (and not just one time). Is it a recent thing or did they do it in their entire history?
Or maybe I should rephrase is a bit. Do they design their own circuitry?
Edited by smitske96 - 06 October 2021 at 9:53pm |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
