Sinbosen class TD |
Post Reply | Page <12 |
snowflake
Old Croc Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3121 |
I'm not sure but opinion in some other forums is that sinbosen have copied some of the cvr designs. some of the morin amps are very similar to cvr amps but have slight layout differences and don't have dsp models which cvr have. of course the two amps pictured are based on lab class td but not straight copies.
Edited by snowflake - 06 October 2021 at 10:52pm |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
In the video i only see some assembly work and pretty low level pcb work.
So still can't say anything about their newer class amplifiers. Regarding sinbosen 'copies'; If sinbosen buy from the same supplier as cvr. I do not see how that can be called copying. Also, 9/10 dsp's in chinese amps are just standard dsp modules that you place before the amplifier. Basically just like any other rackmount dsp but just in the same case (so not like the offerings of the big EU brands). PS: if I am wrong, than i am wrom. But I just do not see anything at the moment that would prove otherwise.
