Sinbosen d2 3000 amplifier repair |
Natedub
Joined: 07 January 2013 Status: Offline Points: 135 |
Topic: Sinbosen d2 3000 amplifier repairPosted: 11 May 2024 at 12:02pm |
I am having a look at an amplifier from my friends rig. It is a sinbosen d2 3000 (chinese) type class d 1u amplifier. It has been faultless for years and defo delivered plenty of power into 2 or 4 ohms. It is specced at 3k at 8 ohms and 5k into 4 ohms, 7k into 2 ohms. It has previously run 4x 18" 1000w drivers no sweat and seemingly has endless headroom.
Anyhow, it has blown an amp channel and I am not sure why. Suspiciously he has also blown a qsc pl4 on one channel around the same time powering the same ohm pukk 218s. I have tested all speakers and cabs with a meter for short etc and can find nothing amiss. I was expecting to find a short. I have inspected the board, it is a modular design and the power supply and one channel work.fine. the damaged channel has a visibly blown IXYS mosfet and a damaged 104j ceramic capacitor. The pcb is intact and undamaged. I have tested the mosfets with a meter and can find 2 that teet faulty. I am not an electronics engineer but have a basic understanding. What else is likely to have blown? What's the chance I replace the 2x mosfets and damaged caps and it works? Regards Nathan
snowflake
Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3443 |
Posted: 11 May 2024 at 3:07pm |
can't advise on the repair, but have you also checked all speaker cables for a short?
Natedub
Posted: 12 May 2024 at 4:47pm |
Yes, thanks, first thing I did was get them to quarantine the cables and speakers
tested everything with a meter and all is fine. They are now using it all with another amplifier with no issues. It's a bit concerning not knowing why.
Natedub
Posted: 12 May 2024 at 4:49pm |
From what I can gather it is internally identical to the CVR D3002
stitchie
Posted: 11 June 2024 at 2:32pm |
Have also been told these are very good amps, what model would people use to power 4x 18" 1000w scoops sub bins? anyone using one in Midlands area where it could be possible to hear it in action? TIA
HumbleDeer
Joined: 04 May 2017 Location: Belgium Status: Offline Points: 35 |
Posted: 19 November 2024 at 11:57pm |
Check the respective opposite polarity transistors as well; check them both for shorts as well as damage to the body diode (the diode that runs antiparallel).
Use the back of a small screwdriver to very lightly tap on any ceramic capacitors of the same type or purpose if they're a capacitor across the mosfets. See if any start to spontaneously fly apart of the likes. If not, just replace the mosfets and start the amp up with a current limiter in series. They generally protect themselves very well. The two amps blowing may merely be a coincidence until proven otherwise. I don't see anything being wrong that would not already be otherwise obvious to the user of the speakers. |
