single 12" mid high cab |
bcs
Joined: 27 September 2010 Status: Offline Points: 216 |
Topic: single 12" mid high cabPosted: 20 July 2013 at 8:27am |
hi guys.
i need to build 4 single 12 inch mid high cabs for general pa work and also use on poles above single 18 br cabs for small parties etc. which will be a better driver to use between these 2,
fane 12-300 http://www.fane-acoustics.com/prod_details.aspx?pid=203 or the fane sovereign pro 12-300 http://www.fane-acoustics.com/prod_details.aspx?pid=340. the comps will be the beyma cd10fe.
regards.
all bass
Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1845 |
Posted: 20 July 2013 at 8:37am |
Looks like the frequency responce of the pro starts rolling of a little higher than the normal 12-300, giving you the option to cross higher to your comps.
I personally never heared the pro version as it's a relatively new driver, but the sovereign 12-300 is a good driver for the money. |
DMorison
Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1740 |
Posted: 20 July 2013 at 10:26am |
I see they've finally updated the specs on those - when they first came out the TS parameters were absolutely identical.
Now that they're updated, you can see that the Pro is a little higher in efficiency and will work in a slightly smaller box, so for this application I'd go for the Pro. Cheers, David.
