Single 18 Build Help |
P3Johns
New Member Joined: 08 October 2018 Location: OKLAHOMA Status: Offline Points: 5 |
Posted: 08 October 2018 at 6:11am |
I have some older Yorkville LS1208 subs.
They sound good and are loud. I’m needing to build 4 for my church. Does anyone have a plan that they KNOW works good for good low end?
JonB67
Are you asking for plans to copy a yorkville ls1208, something to replace it or something to compliment it?
Do you want to reuse the drivers or did you have some others or are you buying new. Do you have something in mind or open to suggestions? |
P3Johns
I like the LS1208 cabinet.
I own 2. I’m needing some subs for our church for some outdoor events. I’m open to whatever. What I like about the Yorkvilles: High output 8ohm Great response Y’all (I don’t need a pole to get the mains over heads) I don’t have the drivers yet. I’m just reaching out for some plans to build my own. I’d like to hit 30Hz and have a peak of around 140.
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4221 |
If you already own a pair then the sensible thing to do is to take the driver out of one of your cabinets, measure it up and build another four of them from your own drawings--This way, you cannot go wrong.
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
Not wrong, but it does assume the OP can get matching drivers - I don't know if Yorkie sell replacement drivers on the open market or not. If he'll have to use some other model, then an exact clone of the Yorkie cab may not give the best result - at the very least it may be worth adjusting tuning for whatever driver is eventually chosen.
P3Johns
That’s what I’m scared of.
Building something that matches but doesn’t perform. I’d like to look at something that’s proven. Driver, cabinet plans, settings and all.
JonB67
Are they going to get used with the other 2 cabinets or as 4 alone?
You ideally don't want to mix within the same passband so if using with the other 2 the new 4 need to be the same. If using them as 4 new ones on their own you'll get lots of good suggestions!
Edited by JonB67 - 08 October 2018 at 2:23pm |
P3Johns
Great point.
I failed to mention this. These will be stand alone subs. Thanks
JonB67
rish
Young Croc Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Thats a tall ask from one driver /cab. Would suggest the old fane 200l cab with XB but thats just me. Rish
mini-mad
Or the B&C 18 sub design as people have had good results with other drivers not just the one it was designed for..
Dub Specialist Sound
Aggred too about the bnc
great sub cab, built loads of them tbh |
JonB67
So recommendations for the b&c sub 18 design, and the fane 200l design.
I'll throw in the 18 sound sub designs from their website, and the g sub designs from this site if you fancy a look at double 18 cabinets. Might also find the tham 15 interesting... high output for is size and held in high regard. All tried and tested by lots of users.
Edited by JonB67 - 10 October 2018 at 12:07pm |
