Skytek 6000w amp??? |
Post Reply | Page 12> |
SantuarySoundsystem
Registered User Joined: 21 January 2017 Location: Midlands uk Status: Offline Points: 80 |
Posted: 04 October 2017 at 11:42pm |
I would never ever want to buy skytek again but 6000w?
anyone got info?
Jesus
bruce@bluff
Registered User Joined: 16 September 2007 Location: South Africa Status: Offline Points: 232 |
Transformer based and 14.1kg me thinks NOT
kedwardsleisure
skytec watts
North Staffordshire |
odc04r
Try knocking a zero off into 8 ohms per channel
Earplug
Yes - I´ve seen their (so-called) 5000W amp and that´s about right. Crap on a stick would be an understatement. |
4AC
Young Croc Joined: 18 September 2010 Location: Netherlands Status: Offline Points: 521 |
Here, a video of the inside:
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
WessexAudioMan
Registered User Joined: 03 April 2017 Location: DORSET Status: Offline Points: 58 |
For skytec id Divide the power stated by 10, then take 30% + off that
for distortion and efficiency issues and you are almost there id expect. Then with that figure if you plan to use it to its max, you may get double digits in minutes if you are lucky before it turns off. If its comes back on again at some point you have one of the better ones ;)
In a nut shelll AVOID !!!!
bruce@bluff
Me thinks they been taking a bit of lucy in the sky(tek) with diamonds ( sorry I could not resist )
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
Damn, the transformer and the chassis could have been used for another project. |
mini-mad
..could have built a nice little 150w plate amp for a home sub with that.. transformer was prob. The only thing worth its weight (literally) in that amp |
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
Yeah, I would also use that chassis for some other projects.. however, that's quite expensive chassis.
Skytec amps, as you said has much less output power than they claim. 2x1000W really is just 2x100W or so with these cheap amplifier kind things. And that's not all.. some models has no output protection, not even fuses! Circuits are really bad design, some of them are self destructing: thermal runaway -> shorted output transistors -> full DC to speakers. So you also lose your speakers when this happens. Looking for cheap amplifier? Go for behringer or T-amp. They are actually quite neat, well built and gives some real output power! Some of them are actually copied from QSC rmx series. I have one Tamp TA-1400 and it really gives about 1kW of RMS power (measured). Edited by Tonskulus - 05 October 2017 at 9:00pm |
SantuarySoundsystem
actual insides :/ :/
how do they actually get away with this???
Jesus
