SL1210 relacement phono's |
4D
Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4364 |
Topic: SL1210 relacement phono'sPosted: 20 August 2009 at 1:31pm |
Hello everyone hope your all enjoying your day.............. ![]() Before one commits to the factory replacements does anyone have any recommendations or preferences for phono cables to fit the trusty SL1210. /tx 4D |
Dom
Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Posted: 20 August 2009 at 1:57pm |
I always just buy a half decent 2-3m phono cable and chop it in half, giving two replacement cables.
CPC has a massive selection
Just don't be tempted with anything too thick as you won't be able to use the strain relief as originally intended. You can dispense with the bottom half of the clamp if you do end up with a cable that's too thick...
eltron
Joined: 21 December 2007 Location: Finland Status: Offline Points: 399 |
Posted: 20 August 2009 at 9:14pm |
This is what i've done. Although, I use (quite thick) car audio rca-cables that have a cable inbetween the phono leads for remote power-up of car-amps and use it as the ground cable. No more flimsy third leads! Just as Dom said I only used the bottom part of the strain relief, just wrap a bit of electrical tape around the cable to get it to fit snuggly. Might not be the most elegant solution, but neither are my 1200's... |
Ben_Lawrance
Joined: 12 January 2006 Location: Brighton Status: Offline Points: 919 |
Posted: 21 August 2009 at 3:07pm |
4D
Posted: 21 August 2009 at 7:04pm |
Cheers Ben. Nice modification provides instant rectification for what is becoming an acute problem what with youth of the dj with their Serato's and lap tops excitedly tugging the flexes clean out of their little phono's ..............then sending their mate in a panic to tell you its "all f**ked". |
B.P.Sound
Joined: 28 December 2007 Location: London M25/M3 Status: Offline Points: 2678 |
Posted: 23 August 2009 at 10:31pm |
Just buy the correct ones from Pansonic they are £8.50 + vat Trade. you won't notice any difference.
http://www.londoneventrentals.co.uk/ https://www.facebook.com/LondonEventRentals
ludofuzz
Joined: 14 September 2009 Location: W.Yorks,UK Status: Offline Points: 13 |
Posted: 15 September 2009 at 2:21pm |
Look up proel stockist the do one exactly for about 1.50trade. =)
