Small, budget install cabs? |
Page 123> |
bass*en*mass
Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4007 |
Topic: Small, budget install cabs?Posted: 22 November 2014 at 5:39pm |
Have a few bar/pub/restaurant type refurbishments comming soon..
Any particular systems you recommend? Speakers aswell as Amps and Zoning etc. - on a budget though ;) (no soundweb blue, no big brand names cabs) Some of the Apart stuff seems alright, same goes for LD Systems imo. Amps will most likely be the tsa4-300s as no need for ELA due to small size and amount of cabs.. Thanks in adcance for your opinions :) |
mini-mad
Joined: 13 July 2012 Location: london Status: Offline Points: 6861 |
Posted: 22 November 2014 at 5:58pm |
If its "budget" stuff why not mdf build the cabs and pay more money for the drivers and get hold of older transformer amps.
corell
Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1159 |
Posted: 22 November 2014 at 6:04pm |
there is a brand new range of 4 chanell amps with transformators by thomann,
even smaller, but also cheaper, than the tsa 4- range. |
bass*en*mass
Posted: 22 November 2014 at 6:05pm |
no time minimad...
3 years warranty from uncle thomann covers my own warranty so no hustle if things go tits up... Trying to get an overview of what might be suitable, will put up a list of candidates asap :) |
dylan-penguinmedia
Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4542 |
Posted: 22 November 2014 at 6:13pm |
Speakers - How big and how budget?
Cloud DCM zoner budget? Amps wise the Thomann 4 ch ones are good value. |
bass*en*mass
Posted: 22 November 2014 at 6:29pm |
good questions dylan..
Amp side is sorted with these el cheapo 4ch jobby i guess Speakers - 3 different purposes so 3 different sizes imo -8"-10" compact tops that will get small sub extension (2x12" maybe as looking for punch rather than real sub to avoid noise issues) - very small floor but edm might be played at dancing levels sometimes.. -6"-8" for the areas that could do with a rather fullrange output but lower levels than the "spot" -very small cabs for the quite areas that still should have some sound at least Not too sure about the zoning/processing yet tbh., not my sort of business, need to take a look at whats available and what exactly is needed now ![]() Inputs will be: dj set playback source mics 1-3 4-6 zones with varying amount of cabs and as usual all on tight budget ![]() |
bass*en*mass
Posted: 22 November 2014 at 6:37pm |
just had a look at the cloud.. - wonder why would you need so many unbalanced inputs nowadays?
Does not make too much sense to me tbh. - dj gear/xlr - mics/xlr - playback/xlr Will look further at whats available to cover the needs :) |
dylan-penguinmedia
Posted: 22 November 2014 at 7:47pm |
With that many zones, you either need to be looking for a scalable / networkable zoner, or a zoner plus xover for the zones which need it. For example you could go for a dbx zonepro with 6 outputs, one for each zone - and use an xover for the areas which have sub. That'd still give you remote control, the right outputs, eq etc, as well as balanced and unbalanced inputs. Only 2 mics I think but you could use a standalone mic pre for the 3rd.
dylan-penguinmedia
Posted: 22 November 2014 at 7:51pm |
Any idea the price points each size speaker should be hitting?
Things to take into account - the impedance of the cabs for starters. People love JBL Control 1 pros, but they're a 4R box, so you can't ordinarily hang loads off an amp. There's a few 16R bits around, for the background areas, we use the Ohm Boutique a fair bit. Glossy, cast ally cube, looks the part, sounds ok, well priced... For bigger though, you need to have a think whether smaller, cheaper boxes, or a more expensive, better quality wide dispersion box (you need half the amount of) will suit you better. |
markie
Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4568 |
Posted: 22 November 2014 at 8:43pm |
Check out the studiospares range. They have their own "Control 1" copy from £15.00 each (Curiously sold for £49.00 a pair..... work that out). They have 10 of the singles in stock.
Or slightly bigger BG206s for £99 a pair. https://www.studiospares.com/Headphones-and-Speakers/Installation-Speakers.htm Edited by markie - 22 November 2014 at 8:44pm |
colint
Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5260 |
Posted: 22 November 2014 at 9:09pm |
Don't be so quick to bypass the cloud stuff, it's very well thought out and normally has a host of hidden features. also (and I don't supose I need to say) don't even think of installing this stuff without a limiter the fact it has a Dj going through the system say's it's going to get red lined. |
nickyburnell
Joined: 06 February 2005 Status: Offline Points: 4408 |
Posted: 22 November 2014 at 9:13pm |
Used
in a pub many years ago. Been faultless, still going strong. The slightly bigger one with the proper looking horn is not as bright and gave trouble when the terminal rotated inside and shorted. The little ones as above are great
Page 123> |
