Small Distro Meters -Was 32A Distro Build! |
Post Reply | Page <1234 5> |
shagnasty
Yeah, gotta say, tidy...
I run the neon rig unfused (like 0.1mm Cable, in a dead short @ 32a (0.5KA in my tests) becomes vapour, I would put a 1A dump fuse into the 240V feed on these babies...
But, that said, for what they cost I can't knock either...
whichever your choose, i would also add the neons.....
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
I'm using a Kelsey distro so I have the 3 neons on there, I'll just need to open it up and put the CT inside. Then I'll mount the meter on a 2 u blank panel on the front of the rack.
100% Earth Moving Bass
shagnasty
You will easy get the meter onto a 1U blank, Use a bit of MT4 trunking with end stops to cover the back of your meter..
You need 5G0.75 cable, all glanded up to export P+N+the 2 Ct lines and make bloddy sure your eart bond your extra panel....
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
Shag, do you mind letting me know what rack case you used for that project?
Ta. |
GAZ.
Ah even better if it'll fit on a 1u! And I was thinking of using a small plastic electronics type box to cover the back of the meter with proper gland on for the cable,and then possibly some sort of mains rated 6 pole connector that I could fit to the Kelsey somewhere to connect the 2 together and be detachable should I ever need to take things out of the rack.
shagnasty
A place to share????
I flipped the rack mounts to give me max stength on the 32A in (didn't work out-right used m5 washersto pack the m4 screws)....
It is F**king tight, like I had to do 3d CAD to fit the stuff in, I used nasty cutting washers to make grounding and I am gonna silicone out everything befor I ship it...
Adam_Iron_Horse
Old Croc Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
Wonder who in the world this distro could possibly be for? :P
Looking great man and pretty excited to see it in my rack and get it used! |
odc04r
I like it. I have a space in my rack for a 1U bit of kit so I think at some point I shall be knocking together something involving one of those meters. Probably the CCM as I never use my kit on generators.
Distro will only be a tiny one, couple of amps and an omnidrive so should be able to fit it all into 1u, will be interesting to find out. |
VentureSound
Young Croc Joined: 18 October 2009 Location: London N20 Status: Offline Points: 950 |
Well, seeing as we are talking meters here, how about this badboy.....
http://uk.farnell.com/hobut/m850-mp1/meter-multifunction-blue-led/dp/1758713 You can get a dedicated CT for it, and if you look at the price compared to similar meters its pretty cheap. Nice thing is you can measure phase-phase voltage too. From a quality brand as well. |
odc04r
Still considerably more expensive than the tested meters, depends on your required accuracy and reliability. For non mission-critical monitoring I'd still go cheap.
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
I've had my eye on one of those for a while. Will need a 3U panel though... |
shagnasty
Nice, does PF as well which is VERY handy, even with 3 x CT it's still not mega bucks (Like £160 inc Vat) and the CCM to do the same job would cost £75 by the time you have a small PSu in there too...
Bit OTT for an amp rack distro, that more for a 63A or a 125A distro IMHO....
