  New Posts New Posts RSS Feed - Small System for Parties (Noob alert)
Ajsski99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Topic: Small System for Parties (Noob alert)
    Posted: 07 October 2019 at 8:18pm
Hi all noob questions incoming...
Recently picked up a pair of Phonic SE715 Passive speakers to use at parties and what not.
however im a total noob and have no idea what amp or what sort of cables i will need to connect them together, to the amp and then into my Pioneer DDJ-400 mixer.
any help would be greatly appreciated, even if someone were to just walk me through it all.
thanks, Ajsski99
djgorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djgorey Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 6:01am
In terms of cables, that will depend on what amp you get and what connections it has on the back.
Your speakers are rated at 200w and 8 ohm so an amp that delivers 200w per channel at 8 ohm would be good. You can get an amp that’s smaller, but you risk driving it too hard to try to get volume out of it and that will risk your amp and speakers.
There are lots of amps out there, second-hand and new, that will do this job. Once you have one you’ll know what the input and speaker connections are.
Gaffa tape is like the force in Star Wars - there's a dark side and a light side and it holds the universe together
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 10:00am
Asssuming you don't have lots of money to throw at this you can get better deals going 2nd hand. Something like these would do the job nicely without spending big money. Make sure you are comparing power ratings at 8 ohm (power ratings at 4ohm are usually about double).
The Peavey has a built in crossover which could be usefull if you think you might want a bigger system in the future.
Avoid skytec and similar amps with big numbers and lots of lights - there is lots of overated cheap stuff out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 2:45pm
my speakers say 250w RMS on the back, surely if my amp delivers more than 250w per channel the speakers will just blow up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 2:51pm
Originally posted by imageoven imageoven wrote:
https://www.ebay.co.uk/itm/Peavey-PV-900-Power-Amplifier-USED/323940066183?hash=item4b6c552387:g:NVAAAOSwtVhdmnrQ - https://www.ebay.co.uk/itm/Peavey-PV-900-Power-Amplifier-USED/323940066183?hash=item4b6c552387:g:NVAAAOSwtVhdmnrQ
https://www.ebay.co.uk/itm/Cloud-CV1000-Amplifier/293258806197?hash=item44479643b5:g:f7sAAOSwjeldgnco - https://www.ebay.co.uk/itm/Cloud-CV1000-Amplifier/293258806197?hash=item44479643b5:g:f7sAAOSwjeldgnco
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 3:23pm
That´s not really the way it works.
To simplify a bit, speakers are rated for a certain (average) wattage for a certain time. They are usually tested with a wide range (white or pink noise), dynamic, (ie changing) signal - with a specified Crest Factor - over a specified time. If they survive without heat, or mechanical damage, then that´s it.
Then you have peak or "music power" ratings, which are usually double - or quadruple that. So, when you play your music through them, they usually can handle up to 2 x RMS wattage for a short period of time. The problem is that the amplifier needs to be able to deliver that signal without distortion, so you really want an amp with 1.5 to 2 x the RMS wattage - but control the peaks so the amp does not clip.
Simple, no...   Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 4:41pm
From that ebay link;
"Peavey PV 900 2 x 450W Power Amp
 PV 900 output power (1 kHz, 0.1% THD) per channel stereo: 180 watts RMS @ 8 ohms, 300 watts RMS @ 4 ohms. Output power (1 kHz, 0.1% THD) bridged mono: 600 watts RMS @ 8 ohms."
See how the "2 x450W" amp suddenly becomes a 2 x 180W amp when you look a bit closer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 6:44pm
so ideally id want an amp thats 2x 250w?
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 8:53pm
You really want an amp with 1.5 to 2 x the RMS wattage
This is the bit you missed.  The reason is also in there.
The old peavey amps are probably a good choice.
Edited by JonB67 - 08 October 2019 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 9:31pm
so all in all
https://www.ebay.co.uk/itm/Peavey-PV-900-Power-Amplifier-USED/323940066183?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3De6df76507ad24819a5f1cb69140dc9f2%26pid%3D100033%26rk%3D4%26rkt%3D8%26sd%3D123897292590%26itm%3D323940066183%26pmt%3D0%26noa%3D1%26pg%3D2045573&_trksid=p2045573.c100033.m2042 - https://www.ebay.co.uk/itm/Peavey-PV-900-Power-Amplifier-USED/323940066183?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3De6df76507ad24819a5f1cb69140dc9f2%26pid%3D100033%26rk%3D4%26rkt%3D8%26sd%3D123897292590%26itm%3D323940066183%26pmt%3D0%26noa%3D1%26pg%3D2045573&_trksid=p2045573.c100033.m2042
this amp would be a good choice? would it roughly output 300w per speaker and that would be a safe operating level for them as i have two?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 9:50pm
Yup. Great choice for its price
The output spec is its max, and unless you're planning to turn all the dials to 11 and just ignore it if it sounds like it's tearing itself apart you'll be fine even if it was more
As an example I run 300w speakers on a matrix 6004, which had 1200watts per channel with zero issues
Edited by JonB67 - 08 October 2019 at 9:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajsski99 Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2019 at 10:18pm
Okay great, so all i have to do is adjust the dials to ensure theres no clipping?
Thanks for all your help by the way sorry to be a pain xD
This page was generated in 0.250 seconds.
