Small system |
Roland
Registered User Joined: 06 December 2007 Location: Netherlands Status: Offline Points: 155 |
Posted: 25 June 2020 at 12:06am |
Hello, I am boring during the lockdown and i have build a small system
The system is a 12" sub and 6,5" mid high For the subs i use the B&C 12PS100 For the tops i use Beyma 6CMV2 with CD1FE on a TD8060 horn Filter i use is the FD250 of Beyma Grill anmd foam is not in house i have ordered , so i have to wait when it is arrived ..... The subs runs from 30 till 90hz and the tops from 90hz Sound greats for me. Amps i tested are the EP4000 of Behringer and a DBX drive rack Nex test i will make with the T amp 4-700 this one i can bridge 2 channels for sub so i have a bit more power then the EP4000 on the sub at 4ohm Here some pics with coating ..... Edited by Roland - 25 June 2020 at 12:13am |
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
Kool....
kufel
New Member Joined: 05 August 2020 Status: Offline Points: 1 |
Hi Roland! It's a nice looking system. Did you already try it with the t.amp 4-700? I'd be interestead to hear your thoughts on how it compares to Behringer EP. Cheers and have fun with it!
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 815 |
Nice little sub. Is it your own design? I tried out B&C sub12 for the 12ps100. That was disapointing.
