Smaller sizes cabinets - is this a thing? |
designalchemy ![]() New Member ![]() Joined: 01 February 2022 Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 01 February 2022 at 10:54pm |
Hi all
Grew up going to free parties and i always was interested in the rigs Decided for fun i would build a mini speaker, no expecting anything to sound good, but just for fun. ![]() Fun projected and turned out pretty well Here is the final version https://imgur.com/a/19vc5tz Iv plugged it in in place of my normal amp and honestly, it sounds much better than my current logitek speakers. This has got me thinking, if i make 5 of these with a 6 inch driver coxial and maybe 1 10 inch driver and connect to a 5.1 amp. I have a few questions. 1. Is this going to sound shit ? 2. Would it be too base heavy ? 3. Is the cab design only for big subs ? 4. Does this make sense, am i being crazy here, if 1 sounds good, 5 would sound great? 5. Can you use scoop/horn design for full range speaker? Thanks for reading, this is a whole new world for me and even tho i have searched i havnt found any information, every is doing 18inch plans no talk of smaller. |
rxs ![]() New Member ![]() ![]() Joined: 23 April 2022 Location: Estonia Status: Offline Points: 6 |
I thought that i was the insane one. You managed to take it little furter than me, i did a cardboard version and sounded sh”t. Still waiting the mood to gome back, to build wooden ones.
Unfortunally i suck at hornresp so cant model any downscaled cabs, (micro W bin, scoops and so on)
Conanski ![]() Old Croc ![]() ![]() Joined: 26 January 2006 Location: Canada Status: Offline Points: 2232 |
1. If one box sounds good then 4 or 5 should sound equally good. 2. Not likely.. the box isn't doing a whole lot at this scale. 3. Yes. The physics of loudspeaker loading is based on wavelengths of sound.. which is very long for sub frequencies, so very large boxes are required to get horn loading of any kind at low frequencies... regardless what drivers are used. 4. Only one way to find out. 5. Yes, high efficiency home audio enthusiasts use all sorts of back loaded horn or transmission line designs with fullrange drivers, the box augments low frequency output while all mid-high output comes directly from the cone.
Edited by Conanski - 29 April 2022 at 3:40am |
