  New Posts New Posts RSS Feed - SMT 212 Scaled Down?
Blaize110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaize110 Quote  Post ReplyReply Direct Link To This Post Topic: SMT 212 Scaled Down?
    Posted: 20 January 2012 at 7:25pm
Just wondering if anyone has ever scaled down an SMT212 cab to run off a pair of something like a pair of 8" and then a 1" compression driver? Or if there is a similar cab to what i'm after about?
And if not, i'm guessing it wouldn't be a simple matter of just scaling all the dimensions? I would try and sim it but i'm not quite sure how with it being ported and having a horn...
EDIT: Just realised this should probably be in Plan Requests, sorry.
Edited by Blaize110 - 20 January 2012 at 7:26pm
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2012 at 8:13pm
Somewhere on the forum there's a guide on how to use HornResp, so download a copy and have a go yourself. It is much more rewarding to do the design bit yourself. And if that doesn't help, all you've got to do is ask and someone will answer... and usually very quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaize110 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2012 at 9:00pm
I have got myself a copy of HornResp, but wasn't sure if could be modelled as a proper horn, given that it is ported...
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2012 at 9:59pm
Read the instructions, and use combined response.
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaize110 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2012 at 10:38pm
Ok, will have a go and see how it goes :)
EDIT:
Just spent the day playing around with HornResp and seem to have found something that works. Thanks for the advice to stick with it, it's all a bit daunting at first but it's alright once you get the hang of it.  Looking forward to building it (eventually!) and seeing how it sounds.
Edited by Blaize110 - 22 January 2012 at 5:38pm
