snafu bares all |
Post Reply | Page 12> |
snafu
Registered User Joined: 17 November 2008 Location: wales uk Status: Offline Points: 352 |
Posted: 02 April 2009 at 3:32pm |
Static Age
Old Croc Joined: 14 November 2005 Location: Oxfordshire Status: Offline Points: 1652 |
Looks like a modfied SMT212, is it? I'm about to do something similar with my SMT's.
Edit: just seen your pic in the other thread, cant be SMT as it pre dates the plans. Edited by Static Age - 02 April 2009 at 3:41pm |
snafu
Hi static I built these cabs about 6-7 years ago,I was inspired by shermann and outline. did,nt know they had a name..
Stray-Sounds
Old Croc Joined: 13 March 2008 Location: Wales Status: Offline Points: 2426 |
Very similar to my Shermann AL3
except im guessing thats an 8'' + 2''. The AL3 are 6.5'' + 2''..... would make more sense having an 8'' I'll get a photo if you want to compare Geth |
<a href="http://www.soundhirewales.co.uk/">PA & Lighting - Sound Hire Wales</a> |
Static Age
Snafu, the SMT212 is a DIY cab, kindly designed & posted by Staiper.
Here's a pic of one of mine, though soon they will look similar to your cabs above.
Stray-Sounds
I got some pics now:
Geth |
nickyburnell
What are the advantages of a flared cab if the flares are outside the cone area?
I can understand the advantage of loading the driver when the flare is within the driver diameter.
Staips version
wafflesomd
Young Croc Joined: 21 September 2007 Status: Offline Points: 811 |
If I could get an 8" horn here, I would modify my smt212's to look similar.
sKs01
Old Croc Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
@ nickyburnell, it should give a bit more directivity to the drivers polars over a direct radiating cab however their is no increaese in efficiency due to hornloading, bit more usefull for arraying but otherwse its just a reflex afaik.
nickyburnell
Thanks, thought so. Bit pointless really then..
doober
Young Croc Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
Nice cabs Dave, how many have you got? What are the x-over points?
Kieran. |
Blahblahblah
snafu
Hi kieran.built 8 of them don,t think I,ll build any more.thinking about building some compact versions using 15 8 2 for center cluster.at the moment x over is 36-125-700-2.5k-16k gonna move low to lowmid to 150 because i get more high bass out of 828 horns.I do like the look of some of the jan audioi horns.If I could get the jan 2x12 in my box i,d be laffin.
