Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - Socapex
Socapex
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Topic: Socapex
    Posted: 12 January 2019 at 9:33pm
looking for lengths of socapex
Connectors
16a breakouts
What’s about guys
one life - have fun!
Force fusion pro audio
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2019 at 4:01pm
I’ve got a box of used socapex cable mount plugs/sockets if you wanted to make up your own cables?
100% Earth Moving Bass
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2019 at 6:40pm
I’ll help - you really, really don’t want to make up your own cables
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2019 at 6:59pm
I’ve got loads!
Send me a little list of what you want and I’ll put you a “package” together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2019 at 11:00pm
You’re right... he wants me to make them.
Making off Socapex is therapeutic as fark LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2019 at 3:46pm
I love a good soldier challenger
Nice and therapeutic
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2019 at 12:13am
A good Solder Pot helps a lot, it makes tinning the wires very easy.
And two small bench vises, one to hold the cable and the other to hold the connector while soldering.
Edited by madboffin - 15 January 2019 at 12:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2019 at 8:09am
And just incase it’s your first rodeo!!
Always start in the middle :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2019 at 9:57am
Easier to start at the bottom with the solder cups aligned the “right way up” and work your way from bottom to top IMO
If you start in the middle it just makes doing the bottom ones of the outer ring a complete PITA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2019 at 8:33pm
Fair enough, different ways same result I am sure :)
I remember the first one I ever done, done the outer pins first. Was a reall ball ach!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2019 at 9:45pm
As long as you end up with a naked cat at the end, who’s complaining? 😂
Bet that was an enlightening experience!
