Sodslaw... |
4D
Posted: 05 October 2019 at 6:55pm |
It's such a bore..
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Online Points: 7442 |
cable ties!
(obviously only joking..) |
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
The IP67 version of the rating below often has the same cut out
E.g. holes drilled for 63A IP44 panel mount often the same as IP67 32A Have to use the same series of connector from one manufacturer Edited by spongebob - 05 October 2019 at 9:43pm |
MattStolton
Car tyre repair? Of the "Rubber coated string that vulcanises into the rest of the rubber of the tyre" type, not the patches?
Once it has gone off, cut flush with something scalpel like. On the bright side, at least one of the 4 holes is in the right place.... I'll get my coat. |
haymere
Young Croc Joined: 28 December 2007 Location: Liverpuddle Status: Offline Points: 585 |
Still conforms to IP 4x
I would get some Black Roof Sealant |
