Solder while driver connected? |
bin juice24
Registered User Joined: 07 February 2020 Location: Here Status: Offline Points: 209 |
Posted: 07 August 2020 at 5:17pm |
Hi, apologies if this is lazy but brief google doesn’t help.
Can I solder one end of cable (about 600mm) while the other end is connected to the driver? Will it cause any damage? I want to put a parallel connection in without fafff of taking driver out. Cheers again.
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 816 |
No problem with that unless you are using a 5000watt solder iron :D
The heat does not reach critical levels with that kind of distance :)
bin juice24
Cheers!
