  New Posts New Posts RSS Feed - Some Bass Horns
Some Bass Horns
 Post Reply Post Reply Page  <1 1112131415>
heinrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2008 at 6:29am
hehehehehehhe...........................they are chinese........hehehehehhehe
everything maybe wrong...............or just even copied from a popular driver!
if you plan to load this driver on an 1850 horn.......forget it!
very muddy and undetailed......performance.....
I've heard this driver best in a reflex cab>>>>>>LOL
Edited by heinrich - 06 August 2008 at 7:30am
.....power is nothing without control....
streetsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2008 at 3:29pm
heinrich, I loaded this driver to my two 1850 with 186 rear chamber (I got them messed up actually) but sounds smooth and clear. I even tested them along side with two CV clone cabs with the same drivers, they just overran the CV's easy. My plan now is to make some more 1850 or 186 (Im not decided yet which one or just continue the 1850 with 186 rear chamber, is it kinda crazy building it? comment please..
Bass matters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2008 at 5:25am
I don't know but, I've only heard those 1850's with NEUSCH drivers still some chinese types...
they really sound good but not with T&T's............
maybe psychoacoustically were diffirent...........and I understand that.....
@streetsounds
from were are u?
nice meeting you here!!!!!Big%20smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2008 at 12:28pm
Thanks mate!!!, im from Batangas. You've mentioned in the other thread that BISIG-ASA is in Alaska, freezin' huh, (sori i thought its in the philippines, its sounds like it is).You must be having a nice job there. From were are you nayway.
Bass matters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2008 at 10:51pm
Quote or just even copied from a popular driver!
A populair driver with 7,5 mm Xmech? Must be a mid then ;)
Regard Johan
mhtplsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhtplsh Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2008 at 2:44pm
Originally posted by streetsounds streetsounds wrote:
Originally posted by suiluj suiluj wrote:
three bee
pic of my driver to use, for you to have an idea, dual stack magnet that's why thicker and heavier
from your sims this will work in WSX, vega bins but complicated to build based on my skills, the 18BPH is much easier, i would like to know how this driver
perform.
Fs: 33.55 Hz Pe: 500 watts rms continous
Qes: 0.285 no: 3.086%
Qts: 0.257
Qms: 2.649
Bl: 29.2 Tm
Vas: 241.1 liters
Cms: 93.72 um/N
Mms: 240.1 grms
Rms: 19.11 kg/s
Xmax: 5 mm
Xmech: 7.5 mm
Dia: 414mm
Sd:1350 sq.cm
Vd:0.673 liters
hi suiluj, is this T & T 18" AK series?
Yes! this r T & T. Made in Shanghai China.
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2008 at 10:15pm
Revised "124" plan [25mm wood] and plot with PD.2450
http://img511.imageshack.us/img511/1581/124planib7.jpg
http://img168.imageshack.us/img168/7185/124plotat8.jpg
www.aggressiveaudio.co.za
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2009 at 12:44am
A scoop I have drawn up. Looks like an easy-ish build.. Won't ever have the sh*t to build 1 though....
39Hz odd Cutoff.
http://img149.imageshack.us/img149/4343/hugofullscoopv1vl6.jpg
http://img83.imageshack.us/img83/1125/hugofullscoopsplez0.jpg
http://img83.imageshack.us/img83/5531/hugofullscoopinputyc3.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2009 at 10:32pm
A revised drawing. The 45deg panels were wrong.... Correct angles added.
http://img156.imageshack.us/img156/4558/hugofullscoopro1.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 1:25am
A kick bin to fit on this scoop.
http://img525.imageshack.us/img525/2127/c18650elscoopkickrh1.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 1:31am
This should upset the fuzzWacko
http://img165.imageshack.us/img165/656/scoopstackjf7.png
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2009 at 7:40am
So I had been meaning to post about this for sometime
but just never got around to it. I own an original Cerwin Vega B36. The plan on the first page, and ever other one I have come across, are all of the B36A which is the second incarnation. Which was also an 8 ohm speaker unlike the original which was 4 ohm.  The B36a has a front mount access panel while the B36 has a removable top (or bottom depending on how you look at it) If I ever get around to taking out the drivers I will measure it all up.
This page was generated in 0.164 seconds.
