Some Bass Horns |
Page <1 1112131415> |
heinrich ![]() Registered User ![]() Joined: 21 February 2007 Location: Calindagan Status: Offline Points: 280 |
hehehehehehhe...........................they are chinese........hehehehehhehe
everything maybe wrong...............or just even copied from a popular driver! if you plan to load this driver on an 1850 horn.......forget it! very muddy and undetailed......performance..... I've heard this driver best in a reflex cab>>>>>> ![]() Edited by heinrich - 06 August 2008 at 7:30am |
.....power is nothing without control....
streetsounds ![]() Registered User ![]() Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
heinrich, I loaded this driver to my two 1850 with 186 rear chamber (I got them messed up actually) but sounds smooth and clear. I even tested them along side with two CV clone cabs with the same drivers, they just overran the CV's easy. My plan now is to make some more 1850 or 186 (Im not decided yet which one or just continue the 1850 with 186 rear chamber, is it kinda crazy building it? comment please..
Bass matters...
I don't know but, I've only heard those 1850's with NEUSCH drivers still some chinese types...
they really sound good but not with T&T's............ maybe psychoacoustically were diffirent...........and I understand that..... @streetsounds from were are u? nice meeting you here!!!!! ![]() |
Thanks mate!!!, im from Batangas. You've mentioned in the other thread that BISIG-ASA is in Alaska, freezin' huh, (sori i thought its in the philippines, its sounds like it is).You must be having a nice job there. From were are you nayway.
Bass matters...
mobiele eenheid ![]() Old Croc ![]() Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Regard Johan
mhtplsh ![]() Registered User ![]() Joined: 27 August 2007 Status: Offline Points: 112 |
Yes! this r T & T. Made in Shanghai China. |
Hugo Biermann ![]() Young Croc ![]() ![]() Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
Revised "124" plan [25mm wood] and plot with PD.2450
www.aggressiveaudio.co.za
A scoop I have drawn up. Looks like an easy-ish build.. Won't ever have the sh*t to build 1 though....
39Hz odd Cutoff. ![]() ![]() ![]() |
A revised drawing. The 45deg panels were wrong.... Correct angles added.
A kick bin to fit on this scoop.
This should upset the fuzz
FlipC ![]() Young Croc ![]() Joined: 25 October 2007 Status: Offline Points: 653 |
So I had been meaning to post about this for sometime
but just never got around to it. I own an original Cerwin Vega B36. The plan on the first page, and ever other one I have come across, are all of the B36A which is the second incarnation. Which was also an 8 ohm speaker unlike the original which was 4 ohm. The B36a has a front mount access panel while the B36 has a removable top (or bottom depending on how you look at it) If I ever get around to taking out the drivers I will measure it all up. |
