  New Posts New Posts RSS Feed - Soundlite Mini Scoop
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2008 at 8:57pm
Originally posted by attraction attraction wrote:
as for the price they are a bit more than Tony's ASS Mini Scoop and also come with a full grill...
What did you pay for 4x mate?
attraction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote attraction Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2008 at 9:54pm
just under 3G's including vat and worth it, solid build not one of the cheap £250 scoops some people are putting out..LOL
Edited by attraction - 22 April 2008 at 9:59pm
Bass is the place
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2008 at 10:05pm
Is that loaded? because i think the £250 you mention is for unloaded cabs
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2008 at 10:23pm
£3000 for 4x Turbomax 900 loaded scoops? LOL
Edited by levyte357 - 22 April 2008 at 10:41pm
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2008 at 10:41pm
i hope you are happy with them... you are already singing their praises so i am sure you will be.
dont worry about the haters... greed has infected their hearts along time ago.
so as someone more knowledgeable then me once sound 'make some noise!'
ps. still need to make it down to tony [shakin dat] a.s.s. to check out his mini scoops... did you hear them? they look sexy i have to admit
Edited by Heathrow_B_line - 22 April 2008 at 10:43pm
smithers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithers Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2008 at 11:32pm
£3k for 4 scoops? ouch.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2008 at 5:37am
oh dear! you could have come here and had the holiday of a life time and left with 8 mini's or 4 dubsub's
good stuff mate
you got any friends like you that you could pass on to me?
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2008 at 11:40am
£3000 for 4 x mini scoops! ShockedShockedShockedShocked
Were the grills Gold plated?
And are the wheels diamond encrusted low profile 22"?
LOLLOLLOL
Id be carefull with them if i was you, someone might be round with his measuring tape *cough*
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2008 at 11:45am
It does sound quite expensive, but it does have custom drivers and no-ones heard them yet, and perhaps the designer actually designed them, rather than making it up and getting lucky *ahem*
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2008 at 12:10pm
It just so happens that i know a few people with those custom drivers!
LOL LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2008 at 12:26pm
Whats the spec of 'em?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2008 at 12:55pm
http://www.recones.com/Royal/900hx.html
Jake think you need a cup of coffee!!
Till then ive highlighted some of the tell tale signs;
Also i think the outer suspension kinda gives it away LOL
Did i mention the Handles look tacky IMO.
Got my self 4 of these last week,one of the best sounding scoops around on par with ASS, i also have 4 ASS scoops. they use the new 900w driver developed on the Fane
chassis
Actual size (H x W x D)
1000mm X 626mm X 784mm
Weight: - 68Kg / 149lbs
Frequency Response: 35Hz - 160Hz
LF Driver: Custom 18.(457mm)
Impedance: 8 ohms
Average Sensitivity 1W/1M: 100dBPower Handling: 900 Watts (AES), 1800 Watts program
Maximum SPL Continuous: 129dB
Recommended Crossover: 120Hz
Protective Grill: Black Perforated Steel
