  New Posts New Posts RSS Feed - Soundsystem for reggae/dub enjoyment-Home version
Johnnyspeakerp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnnyspeakerp Quote  Post ReplyReply Direct Link To This Post Topic: Soundsystem for reggae/dub enjoyment-Home version
    Posted: 16 September 2020 at 5:35am
Hi all!
First post here and that says enough. I’ve been considering for years to build a soundsystem to enjoy my reggae/dub vinyl collection but never did because it seemed a very far away land the pro audio territory. Now after some research and forum browsing I think I can try.
So Now I need your experience and advice. This set will be placed in my living room which is about 80-90 square meters. It will have to include scoops because I love that sound. Dimensions must be acceptable or my sweetheart will make it disappear soon. Loudness obviously is not important. On the contrary I’d like a set which sounds good also at low level. 4 way. These are the options for The sub section I took into consideration:
1-a single 18” super scoop
2-two 10” scoops based on Jim Frizle’s Yout scoop
3-a single 18” or 15”Mini scoop
I really need someone to advice me on this so that I can figure out the rest of the set.
Thanks for your patience!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2020 at 11:33am
Living room, buy/build 2x18" reflex cabs, load with 2x Fane 18XB800W.
Build  2x12 +1" Compression box on top.
That will make all Reggae sound good.
Pointless putting Scoops in living rooms, real Reggae lovers don't do that.
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2020 at 3:43pm
18" scoop in the front room won't work. I've been there and done that
Also, a scaled down version won't play as deep as a single 18" reflex, which quite frankly, will still be ridiculous in a front room
We get complaints from a single 12" Yamaha active monitor
The other problem is that "PA" gear generally doesn't sound great at low volume, that's why you have high sensitivity Hi-Fi drivers
BUT, if you genuinely want something fun for home, and mid level volume isn't a problem then...
18" reflex sub, 15" reflex kick, 12" + 1.4" + bullets will sound exactly like a mini rig, in a small package
Edited by Sinai Sound - 16 September 2020 at 3:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2020 at 5:38pm
B&C DE25 1" Compression driver, with B&C ME45 1" Alu horn, pure loveliness  for home highs and sizzle.
Especially if mated with Class AB amp on Mid tops.
Peavey GPS3400 is also ultra smooth on Home Sub, 2x15" or 2x18".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnnyspeakerp Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2020 at 9:43pm
Thanks for the replies. I knew the idea of scoops in a living room would get criticism. Ridiculous means they are oversized for that kind of environment? This is why I took into consideration a scaled down version. I never listened to a 10” or 12” Scoop playing so I would like to know if someone has. I’m not expecting the feeling of a full size set but an acceptable compromise. Reflex could be an option too.
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2020 at 10:44pm
Livingroom is usually just too small space for a scoop to make them sound good. Its all about room acoustics and modes.
I have been storing two hog scoops in a living room and ofcourse tested them.  Yes, there is ALOT of bass pressure right in front of the stack and things are rumbling and flying around the room.. but it just doesn't sound right overall.
I also have two 12inch scoops but..well, they sound dry and honky and does only 70-150Hz. Very efficient tho.
Properly designed Reflex or even 6th order bandpass tuned to 30-40Hz will sound better generally speaking in small spaces.  You may try something like Fane 18SB/XB or RCF LF18G401 for a good price/performance.
Bams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bams Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2020 at 11:06pm
As above... tried to run two jbl 4530’s as a part of my hifisetup in a medium sized living room and it just didnt work. Too much reflections and cancellations going on.
Chris Grimshaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Grimshaw Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2020 at 11:06am
My current HiFi speakers use B&C DE250s for 1kHz and up. They sound excellent.
I've done some testing, and found that speakers respond linearly even at extremely low levels (as in, I couldn't hear the sweeps happening in-room, but a Beyer MC930 close to the cone picked them up just fine), so it's more likely the electronics that are operating way down in the noise, causing degradation.
If the system is capable of 140dB@1m, you're throwing away a lot of digital bits by running at 70dB@1m.
Chris
Quality sound from Sheffield
www.grimshawaudio.com
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2020 at 2:55pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
Yes app , very nice to my ears broBig smile, drops nice/heavy nice bass tones to it, yu need to really it manSmile
ive added a old vintage Cast Horn/comp to the stack now , so it runs 4way...nice, yu can just about see it top right .....on top of my deck..
heard this at dub specialist yard Heart Thumbs Up  mite be too much for sum but sounds heavy and crisp Nuke
Edited by jammin75 - 19 September 2020 at 3:00pm
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2020 at 4:45pm
 If by "doesn't sound great" you mean a system calibrated for high SPLs generally lacks bass a low output levels that is more about how human hearing works and is easily compensated for. Otherwise the advantage tilts heavily in favor PA drivers as they can produce home listening SPLs with only milliwatts of input in some cases(compression drivers) which means they are only producing a fraction of the distortion that hi-fi drivers produce at that SPL.
That's just a contradiction in terms.
Yes but it's still probably not going to be an issue.
A. But depth relates to signal to noise ratio only not to resolution of sampling, and modern digital equipment performs equally well over a wide range of bit depths.
B. If signal levels are low enough to make this a problem it's easy enough to run all gain stages hot and turn down the amplifiers input attenuators.
KWB75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KWB75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2020 at 8:18pm
Nick Sasquash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick Sasquash Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2020 at 1:17pm
reggae sound system has been my life for 20 years+ ... a pair of these for home use, jobs done Smile
