  New Posts New Posts RSS Feed - Soundsystem set up
Soundsystem set up
Rakkeby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rakkeby Quote  Post ReplyReply Direct Link To This Post Topic: Soundsystem set up
    Posted: 15 March 2021 at 9:25pm
Hey this is My first post here.
I have baught a soundsystem from an retired dj and I was wondering what would be the Best way to set it up.
 At the moment i set up with All speakers but only 3 amps
Amp1 1400 to the 4 181's at Paralel mono 1505 watt 2 ohm
Amp2 1400 to the 2 182r agin running at 1505watt 2 ohm.
Amp3 800  vibe 30mk2 has 1 800 905watt 2 ohm
Tops
 2 vibe30 mk1 whith 15" stage line 38/300 drivers rated 800 watt 4 ohm
Subs
4 mach 181mk2 with percsion 1s 186/2 drivers, the bin is rated for 8 ohm 1200watt, the drivers is rates for 700watt 8 ohm.
2 mach 182R with original drivers rater for 2400watt at 4 ohm
Amps
Crown cls 460
Stereo 2x240watt 4 ohm 2x200 8 ohm
Bridged 1 x 455 8 ohm 1x395 16 ohm
Paralel mono 1x400 4 ohm 1 x 455 2 ohm
Crown cls 800 x 2
Stereo 2 x 425watt 4 ohm  2 x 300 8 ohm
Bridged 1x900watt 8 ohm 1 x 645 16 ohm
Paralel mono 1x640watt 4 ohm 1 x905 2 ohm
Crown cls 1400 x 2
Stereo 2x700watt 4 ohm  2x500 8 ohm
Bridged 1x1500 8 ohm 1x1075 16 ohm
Paralel mono 1x1050 4 ohm 1x1505 2 ohm
Lem dpa 2k
Stereo 2x500 4ohm 2x350 8 ohm
Bridged 1x1000watt 8 ohm 1x700 16 ohm
Dbx231 eqalaizer
Samwick dv 230 crossover
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2021 at 3:56pm
The cls1400 amps really aren't big enough for the subs, and parallel mono doesn't help it produces the same total output power as 4ohm stereo.
So the only thing you might try different(if possible) is to biamp the Vibe30's with the Lem driving the compression drivers, cls800's driving the 15's.
