SOUNDSYSTEM SOUND-OFF - 10 MARCH 2013 |
Post Reply | Page 123 8> |
Motion54
Old Croc Joined: 13 November 2010 Location: London Status: Offline Points: 1753 |
Posted: 07 February 2013 at 12:19am |
Featuring COMPLEX SOUND (FLETCH) SHABACH SOUNDS (SHABACH SOUNDS) QUALITY ASSURED SOUND (DJ WHYTE & CREW) EBONY SHOWCASE SOUND (MR B & DJ LEVY) Entrance £5 (Ladies Free) SUNDAY 10th MARCH 2013 To be held at:- Golden Palace Banqueting Suite, Unit 39 Hastings wood Trading Estate, Harbet Road, London N18 3HT Nearest Train/Tube Station - Silver Street (BR), Walthamstow Central Local Buses - 34, 444 Below is a map and directions to help you locate venue.The blue spot roughly marks where venue is located on map. I suggest approaching from the Argon Rd end of Harbet Rd. Follow the road up passing car pound on your left and as the road starts to bend to the left past the first large trading estate and MOT garage you should see on your right, signs for "Hasting Wood Trading Estate" and "Golden Palace" and "Eddies Cafe" Turn right into estate and go through barrier by pressing buzzer and asking for access to Golden Palace. Continue pass the first building on your right and then turn right and continue straight ahead. You will see "Eddie's Cafe" and "Golden Palace" straight in front of you...........you have arrived!!! Edited by Motion54 - 11 February 2013 at 5:20pm |
Motion54
THIS EDITION ALLOWS SOUNDS TO BRING 4 SUBS MAX. A sound can bring upto 4 sub boxes no bigger than a scoop with each sub cab comprising a max of 1 driver (2 drivers if reflex). Kick,upper bass or low mid cabs are also allowed but must play kick, high bass or high mid frequencies only!! All scoops will be classed as sub duty cabs only. We
are aware there are gonna be different views on definitions of sub,
kick, driver amounts in cabs etc but we believe the cab size is more
important than the 1 driver or 2 per cab in sub boxes roughly the same
volume................BUT UNTIL PROVEN DIFFERENT AT ONE OF OUR EVENTS WE
WILL STICK TO THIS THEORY!! EACH SOUND IS ENTITLED TO AT LEAST ONE 32amp CEEFORM CONNECTION REGARDLESS AT WHAT TIME THEY ARRIVE SoundSystem Sound-Off is a soundcheck after all, but we would still like to see sounds entertaining the punters with music and vibes with their microphones as this is key to keeping these kind of events alive! |
SURFA
Registered User Joined: 14 February 2009 Location: LONDON Status: Offline Points: 133 |
WOW, This sounds like a good night...
Not sure where Shabach sound come's from... But 3 Nth london sounds in 1 arena....
A POSSIBLE SHOOT OUT ON THE CARDS.........
Jah Lion
Registered User Joined: 10 January 2013 Location: London Status: Offline Points: 32 |
A who Dis shabach?
Tweeter_Box
Young Croc Joined: 23 June 2012 Location: London Status: Offline Points: 859 |
Hard new system pon the block
Jah Lion
which block dem de pon. me nah c dem de bout.......mi no bout Ren but him APS. big sound dat. him musi fill in fe help out uno.
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
will ren be using his aps preamp on the shabach set?
Motion54
Not sure what SHABACH sounds will be bringing.
Flyer change requested. Edited by Motion54 - 11 February 2013 at 5:24pm |
Jah Lion
So you a tek arf Ren and Tekasis. So who dat leave?
levyte357-
I'll be bringing a set into GP under the name "Shabach Sounds". As this is a "soundcheck", will be bringing guest DJs, & my Lev .44 Scoops (PD1852 loaded), for 2nd test, this time powered by Pre-Amp. Respects to "the crew" for making this possible, & Kutty providing assistance/PD1852s. Edited by levyte357- - 12 February 2013 at 12:49pm |
Jah Lion
levyte357-
Thanks for that. As no man is an island, have assembled team of experienced personnel, to hopefully ensure entertaining night out. Edited by levyte357- - 12 February 2013 at 1:09pm |
