Soundweb Green taking upto 30 mins before working? |
Post Reply | Page 12> |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Posted: 09 April 2017 at 11:09pm |
So I've just been informed that one of my installs which is using a 9088iis is taking forever to start up. Ie upto 30mins before the music comes through. But once it's working it's working fine even if you push it.
Apparently it's been happening for months but they've only just told me. Any ideas what's going on? The amps don't seem to have an issue.
kedwardsleisure
SMPSU issue I'd say. It will only get worse.
North Staffordshire |
SamV
Repairable?
cravings
this seems to happen with some BSS power supplies. i never solved it on my minidrive.
SamV
Still working?
cravings
no i had a go at fixing it (i don't know anything about switch mode supplies.. but i swapped all the electrolytics, must have messed something up) and it doesn't work at all now.
before i killed it, it was taking a few minutes to power up and if you listened carefully there was a high pitched noise coming from the power supply area, increasing in pitch slowly while it charged or warmed up or whatever. and there was a bar here i remember had an omnidrive with a big sticker on it saying " don't switch me off!" because it would take about a half an hour to come back on. (heh, i see it had its own facebook page.. link and http://forum.speakerplans.com/bss-mindrive-no-power_topic74697.html |
bob4
I've successfully fixed a 9088 (first gen, not II! ) power supply by swapping the electrolytics. The unit didn't have power up issues mind you, but was suffering from some substantial hum/noise.
I hope the owner of the chinese restaurant where I installed it never calls me back though….. fingers crossed……
Trying to fix it could be worth the trouble, but maybe it would be better to find a replacement before pulling out the dodgy one for repair? I wouldn't want to be soldering against the clock, just to bodge it or find it's beyond repair in the end |
shagnasty
There is a row of 0.1" molex pins that connect the PSU to the DSP with jumpers, you can make a 0.1" female to female lead and use another SW green to power up yours, if that cure it then you need a PSU fix, Mr BSS @ dpa-audio is an real option, but, and here is the but, if it is only caps, it is an easy fix, if it is more, you may start a job you need Gearge to finish, Baldock is a far run in a hurry.
I have BSS 9088 and 3088 if you need a unit to cover your gig during the repair.. S
SamV
Ah cheers chaps :) Sean do you know if I can just upload the same install file to the 3088 that I used for the 9088 or will I need to recreate?
shagnasty
Hi Sam
No, you have to right click on the DSP mode in the top map and hit covert to 3088!!!! :)
SamV
Awesome thanks, will have a look tomorrow.
service dept Steve
Old Croc Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2034 |
Although these are usually a simple repair please remember that you are dealing with 335v which can sting, you may be better taking these to someone in the know...
We are not "They", We are "The others"http://www.servicedept.co.uk -
