  New Posts New Posts RSS Feed - SP12 and SP10 Midrange horns
Topic ClosedSP12 and SP10 Midrange horns
 Post Reply Post Reply Page  <12345 13>
Max_SPL View Drop Down
Direct Link To This Post Posted: 31 July 2012 at 1:20pm
Hi Mykey
Very nice job on these, could you please PM me about delivery times for 4 of these
Regards
Shaun
GUSTEK View Drop Down
Direct Link To This Post Posted: 31 July 2012 at 3:50pm
how would this driver go? or any of the new B&C 12''
http://www.bcspeakers.com/product.php?id=363
-bun down babylon-
mykey- View Drop Down
Direct Link To This Post Posted: 01 August 2012 at 8:57am
That be a bass driver Gustek
any good midrange 12
Direct Link To This Post Posted: 03 August 2012 at 3:33am
Originally posted by el_dj el_dj wrote:
dispersion and in what frequency range?
Dispersion 60 H  x  40  V
Frequency range is 128 hz - 2 k
usable frequency range is 135 hz - 1.6 k
Edited by mykey- - 07 August 2012 at 11:49am
supremesoundz View Drop Down
Direct Link To This Post Posted: 03 August 2012 at 5:08am
Looks impressive Mykey. What is the ultimate driver for this? Might be an idea just to list the best and most suited 12's as it will get asked again and again. For non cab builders have you a design which can be given to a carpenter etc. Pm me if necessary
Direct Link To This Post Posted: 03 August 2012 at 5:20am
Thanks supreme
12PE32.
Graph is with the Paudio SN12B.......lovely sound.
See Tony ASS on here for them
Direct Link To This Post Posted: 03 August 2012 at 5:22am
You mean to house the SP12?
Direct Link To This Post Posted: 03 August 2012 at 5:58am
Yep. If it to be used in non instalation uses. Together with a good 1.5 or 2 inch cd
Father-Francis View Drop Down
Direct Link To This Post Posted: 03 August 2012 at 6:24am
you could just build an mt121 shell shape, you have the depth of the SP12 , and then just drop it in.
Aztor View Drop Down
Direct Link To This Post Posted: 05 September 2012 at 11:14am
Can you repost the prices?
Is it possible to get discount if buying 4+?
jwdrain View Drop Down
Direct Link To This Post Posted: 18 October 2012 at 3:57am
Can the 12" horn section of an MT121 be modified to accomodate these?
Direct Link To This Post Posted: 18 October 2012 at 7:25am
Cut out is 515mm x 380mm
Horn size front is 558mm x 427mm
This page was generated in 0.703 seconds.
