Speaker advice |
zeo
New Member Joined: 03 July 2014 Status: Offline Points: 8 |
Posted: 03 July 2014 at 1:46pm |
Hi!
I've been using the original t-amp together with a pair of fullrange Philips 22AH461/12R with nice results when EQd. But now I feel like upgrading in order to be able to play louder and without the need for EQ. Recently I ordered a Muse M50 (2*50W class T) and plan to build a couple of small and lightweight cube speakers. I have been looking at 2 way car speakers (4" to 9") like Infinity and JBL with high efficiency but also fullrange drivers. I don't like the sound from metal tweeters and I wan't hearable low bass. I understand that the bass response is affected by the cabinet size and design. The car speakers sound best with a sealed cabinet? and the fullrange with a bass reflex port? If I want the cabinet to be as small as possible what would you choose? Do you have any hints on good value for the money drivers which handles about 50W RMS? |
lutkeveld
How big may the cabinet be?
zeo
The philips cabinet is 24 x 34 x 16 cm (10" x 13" x 6") about 13 litres. Preferably not bigger if possible.
lutkeveld
In total or per speaker? Have look at the Dayton ND105.
zeo
Per speaker.
mr. doom
Registered User Joined: 08 September 2010 Status: Offline Points: 266 |
Metal tweeters are are not the problem. Some of the smoothest sounding speakers use metal domes, the magic or fail happens in the x-over.
zeo
Ok, I didn't know that. I was thinking about those metal cone tweeters. I did own a couple of Monitor Audio S8s and those tweeters were fine (and most likely the crossovers too ;) )
zeo
I think I will go with a couple of JBL 4"s and build them into two small cube cabinets and add a third cube (or tube) as a subwoofer with two Dayton ND105 4ohm elements powered by a Muse m20 ex2 TA2020 (I already have one). I should probably use an adjustable low-pass filter for the ND105s?
zeo
Found one http://www.newegg.com/Product/Product.aspx?Item=9SIA2C51AX4048 |
zeo
I listened to some car speakers and they sounded pretty awful all of them =( |
lutkeveld
Two ND105's in a 18 liter cabinet tuned to 44hz running fullrange.
Or build the Boominator Mini.
