speaker foam |
| Author | ||
invader
Joined: 21 November 2017 Location: lyme regis Status: Offline Points: 37 |
Topic: speaker foamPosted: 25 January 2026 at 1:39pm |
looking for suggestions on best glue to use for glueing foam to meal speaker grilles
Andylaser
Joined: 16 April 2010 Location: Southampton Status: Offline Points: 392 |
Posted: 25 January 2026 at 2:15pm |
3m super 77
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 25 January 2026 at 6:46pm |
It's true. It's pricey, but other ones just make a mess.
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 25 January 2026 at 7:42pm |
Evo stick spray contact adhesive worked for me in the past.
madboffin
Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1720 |
Posted: 26 January 2026 at 3:48pm |
That's very hard to control and can make a terrible mess. You might get away with it after a lot of practice on scrap parts, but I wouldn't... The Scotch 77 is much better for this application and is used in the industry (including at Martin Audio when I was there). But yes it is very expensive. |
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 7752 |
Posted: 26 January 2026 at 4:41pm |
I've never used the Scotch 77 stuff, but have used several generic contact sprays, including the Evo & never had any problem. What exactly do you mean by "terrible mess"? I think that you just need to be careful & use careful, short bursts & not spray the stuff all over the place like a maniac!! |
cravings
Posted: 26 January 2026 at 5:10pm |
if you're doing foam on the inside of the grill, other glues make a spidery mess.
but if you're gluing foam to the outside of the grill, then others are probably fine. |
Earplug
Posted: 26 January 2026 at 6:16pm |
Ok. I usually stick the foam on the inside, but have had to repair a few with the foam external. Never really noticed the problem. Maybe I've been lucky.
smithers
Posted: 04 February 2026 at 10:31pm |
As per forum recommendations, I used the 3m super 77 to refoam a basys rig (foam inside the grill), its about £13 off amazon.
Honestly, dont waste your time using anything else, super 77 works exactly how you hope it would. the results are very impressive.
