Speaker grill. |
bin juice24
Registered User Joined: 07 February 2020 Location: Here Status: Offline Points: 209 |
Posted: 01 July 2020 at 9:56pm |
Hi, I’m having trouble finding grills to fit over drivers with external diameter of 470mm.
Any suggestions? Big thanks.
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2460 |
You could try Markie on the forum.
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
might try searching for 'grille' with an E, I think 'grill' is american or in the UK means something you do you sausages with
North Staffordshire |
bin juice24
Grilliant.
Thanks
kedwardsleisure
bin juice24
Too small but thanks.👍
kedwardsleisure
470mm is an 18in driver isn't it? Or have you got a bigger one?
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
Not all manufacturers use exactly 18" (which would be 457mm) - so I presume the issue is that "standard" round grilles don't have enough clearance for OP's drivers which seem a bit bigger than average.
kedwardsleisure
All the circular grilles I@ve seen normally go on the driver, not over it, unless there are oversized ones available? Not seen any.
