  New Posts New Posts RSS Feed - Speaker Management
Speaker Management
Fracture_clinic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fracture_clinic Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2020 at 1:48pm
Originally posted by fatfreddiescat fatfreddiescat wrote:
A really useful feature to look for is separate compressor and limiter on the outputs, so can set comp for thermal control and limiter for over excursion and clip prevention.
I thought too much compression raises RMS?
JBK View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JBK Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2020 at 3:33pm
It depends on the compressor, it's all about the time factor
https://en.wikipedia.org/wiki/Dynamic_range_compression#Peak_vs_RMS_sensing
peak compressor will activate instantly if the voltage gets above a certain threshold.
So yes continuous peak limiting = clipping = distortion and may lead to higher RMS value.
RMS compressor will compute RMS value over a period of time, and will lower the signal for a certain period of time if the computed value exceeds the threshold.
pseudo-RMS can be achieved with peak detection + long time constants (ie attack set  to the min, and release set to the max) but that's not an optimal method
https://www.facebook.com/rootikalvibeshifi
http://jbkaudio.fr
https://www.youtube.com/playlist?list=PLKB8xPHqsVywM2EgtOaMjdgfIUf_-kFdV
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fracture_clinic Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2020 at 3:46pm
<div id="gtx-trans" style=": ; left: 387px; top: 195px;"><div ="gtx-trans-icon">
Ah nice one JBK, I'll do some more reading too. We often use the xca so I guess I should learn more about that compressor too.
