Speaker voice coil |
Page 123> |
Fred_reun
Topic: Speaker voice coilPosted: 19 June 2024 at 6:24pm |
Hi !
I’m starting to repair my own speakers, and I got some issues with the replacement of the voice coil. I got 3 ref different and no indications of the height of the cooper around the magnet, if you guys got this info somewhere ![]() I got 2 wharfedale D-161, 1 B&C 18ps76 and 1 B&C 18ps100 Thanks you ! |
VECTORDJ
Joined: 11 June 2006 Location: United States Status: Offline Points: 585 |
Posted: 19 June 2024 at 10:46pm |
It is clear You should not be Reconing...I suggest taking the Speakers to a Local Pro Reconer....Sorry to be Mean but the Truth can Hurt.
BrainlessTekno
Joined: 20 February 2023 Location: Slovakia Status: Offline Points: 381 |
Posted: 20 June 2024 at 7:02am |
somewhere here there is detailed step to step guide for reconing
BarSick / barsik soundsystem
Dont want to toot my own horn but toot toot |
Fred_reun
Posted: 20 June 2024 at 7:13am |
The thing is : there is a specific height to glue back the new coil but I didn’t get the instructions with the coil that’s why I’m asking, I do not ask for your opinion about my reckoning skills, everyone start something by trying and learning. Pleas be kind and have a good day
BrainlessTekno
Posted: 20 June 2024 at 8:01am |
Sure make the recone yourself, worse that can happen is that you lose a recone kit so deffinitly you try to do it yourself
Here is the guide in case that you missed it https://forum.speakerplans.com/a-recone-guide_topic29715.html |
Fred_reun
Posted: 20 June 2024 at 8:24am |
Thanks for your reply,
As I understand for long coil the height I need to get btwin the bottom of the magnet hole and the bottom of the coil is Xmax in mm?
BrainlessTekno
Posted: 20 June 2024 at 8:36am |
Look you need to put the voice coil that way that the coil never leaves the magnetic gap, yes you can basicaly say that if the xmax is 10mm you need the VC at least 10mm from the magnet, however i would add an extra 2mm on top of it, not sure if that is the standard procedure
Fred_reun
Posted: 20 June 2024 at 8:39am |
I just tried, I’ll let you know if it sounds better or if I still get this shitty noise at loud level
BrainlessTekno
Posted: 20 June 2024 at 9:46am |
Voice Coil Overhang: (Hcoil - Hgap) / 2
Position from Bottom of Gap: Xmax + (Hgap / 2) - (Hcoil / 2) Let's assume: Xmax = 5 mm Height of the magnetic gap (Hgap) = 10 mm Height of the voice coil (Hcoil) = 20 mm The bottom of the coil should be positioned: Overhang = (Hcoil - Hgap) / 2 = (20 mm - 10 mm) / 2 = 5 mm Position from Bottom of Gap = Xmax + (Hgap / 2) - (Hcoil / 2) = 5 mm + (10 mm / 2) - (20 mm / 2) = 5 mm + 5 mm - 10 mm = 0 mm This means the bottom of the coil should be flush with the bottom of the magnetic gap in this specific example, allowing for equal movement up and down corresponding to the Xmax.
Fred_reun
Posted: 20 June 2024 at 9:58am |
So how do you got the Hgap in this exemple ? Because I got Xmax (8mm) coil height (23mm) but no indication of hgap
BrainlessTekno
Posted: 20 June 2024 at 10:09am |
you can sometimes find it in specification, but it seems to be rare... I found an app online but i actualy never used it so try to double check the results or get the advice from someone with more knowledge
the app -> https://www.kjmagnetics.com/gap.calculator.asp |
Fred_reun
Posted: 20 June 2024 at 10:25am |
I did not get result in mm or inch on your site :/ is it possible maybe to measure it with specific tools?
Page 123> |
