Speakerplans DM2 build |
Post Reply | Page <1234> |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
Truly awesome!
valve head777
Got to build 2 surely!!
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Online Points: 2433 |
I only built the one as it’s intended purpose is to use as a drum fill.
However the thought has crossed my mind more than once! |
100% Earth Moving Bass
mini-mad
...or a one box solution for a house party!!!
I know drummers love it loud but surely thats concert level loud(?) |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
I like it! Once you get it in use I'm interested how the single 1" keeps up with the rest though... ...it's got a big job!
rish
Young Croc Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
I assume if you cross the comp as high as you can, it should be able to keep up.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
Let us know how it sounds, fancy building a pair for my factory system :)
GAZ.
Got quite a bit more done today. Finished the speakon input, and did the stipple coat on everything apart from the bottom and the baffle.
Still more to do, but was finished enough to load it and wire up all drivers so.... looks really good! So temporary wired the amp rack up to it, set up the crossover and fed it some signal. Got everything dialled in and cranked it up a little bit. A warm fuzzy feeling came over me as everything in the lockup rattled! Couldn’t really wind it up today as the landlord was in next door but it sounds absolutely mint! It sounds like a stack of speakers rather than just one! Very nice full range sound. The fane CD 150 has no problem Keeping up with everything else. Well pleased so far! |
njw
Very nice! Reminds me of the Clair Brothers S4. What crossover points are you using?
GAZ.
250hz and 3.5khz
partya
Registered User Joined: 06 September 2013 Location: New Zealand Status: Offline Points: 105 |
Very nice work!
Reminds me a bit of a pair Community CSX70's I used to have. Effortless SPL, pretty hard to move around though.
Turn it up! Turn what up?
Markko
New Member Joined: 04 February 2019 Location: italy Status: Offline Points: 3 |
Hello, very beautiful, I would like to build two, for my hifi system. I would like to use passive cross-over. Can you tell me where to find the filter scheme? Thank you.
