Spektre double 18" 'scoops' |
Page <1 34567> |
levyte357 ![]() The 10,000 Points Club ![]() Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Term scoop commonly used to refer to curved sections in rear loaded horns. However many "scoops" these days have no "scoop", but have approximated curve from 2x or more angled cuts. Does that now also make these "not" scoops ? More accurate definition of a scoop is rear loaded horn. Even though Wembley bline cabs have no scoop, or uniformly increasing horn, or horn mouth per say, they do possess "pseudo" rear horn loading. Therefore are not just reflex cabs. As these cabs are based on Wembley Blines, they are also therefore not just reflex cabs. As no reflex cab, can match the SPL, generated by a "mini scoop". In the UK, the term "mini scoop", is often used to describe sub cabinet, with some type of rear horn loading, which causes sub SPL to exceed that possible from just a reflex cab, regardless of uniform horn expansion or lack thereof. EDIT:Spoke to my "source" regarding these cabs, and he "insists", the original cabs were manufactured in South London by Cas, the result of 2x Wembley Blines being fused together. This was before 2007, then a batch being transported to Birmingham. ![]() As Mykey stated, A similiar cab was present in Shortmans workshop at one time, as I also saw it in person. This was probably mid 2007. Will find the pics on the forum now. Edited by levyte357 - 20 February 2012 at 8:06pm |
Seems the cabs seen in shortman workshop, were similiar but different driver orientation.
![]() Edited by levyte357 - 20 February 2012 at 8:17pm |
Double post
PauliePaul ![]() Young Croc ![]() ![]() Joined: 14 August 2009 Location: Birmingham Status: Offline Points: 1484 |
If you've noticed I've been a bit sketchy about the details of the designer/builders/place of build/construction/machining details etc, i do know a lot more about these boxes and the people behind them, but have chose not to divulge all of the info. Work started on the project a long time before 2007... infact, years before and, as previously stated, the development/build happened in Birmingham.
Guess, best way to clarify this, is people in the know at the bar after GP gig, over some cold brewskis. ![]() Edited by levyte357 - 21 February 2012 at 12:52pm |
No problem.... I'll come with documents, pictures, invoices, the designer and the builder... what you got?
1st round. ![]() And the South London person who was around Cas, the first time he built them. Edited by levyte357 - 21 February 2012 at 12:59pm |
Be careful you don't come with.... it would be unfortunate....
Yes.. I won't be saying anything, will let my "source" dispel all of these. |
Jokes....
brokenjoe ![]() Old Croc ![]() Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3712 |
jeez.. i saw these at the q club around 2001 ! and they looked old and battered back then!
error 404
vibez ![]() Registered User ![]() Joined: 21 January 2010 Location: wolverhampton Status: Offline Points: 316 |
interesting reading gentlemen. i heard supaclick play with luv injection at the drum just before christmas and i'm sure he was playing some of these. he was also using vz5000 and sounded rubbish. technical problems, feedback and a whole host of other problems.
@pauliepaul.....i have met up with you so many times and had no idea you were so actively involved in my scene and full of so much knowledge/history, i look forward to the convesation next time i see you. i clearly need to do some more homework on the people i deal with as i now feel rather embarrased. anyway, i must dash. i'm off to the drum again to check out qualitex at the drum with luv injection. |
Page <1 34567> |
