Spot the deliberate mistake |
Page <1 891011> |
APW ![]() Young Croc ![]() ![]() Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1137 |
Yes......
But I don’t want to spoil it for everyone else!! |
fatfreddiescat ![]() Young Croc ![]() ![]() Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1048 |
Could leave a short comment but pushed for time
Robbo ![]() Old Croc ![]() Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4192 |
Got to be yet another interpretation of "Bridge Mode"
JulianDA ![]() Registered User ![]() ![]() Joined: 29 May 2018 Location: Soest, Germany Status: Offline Points: 110 |
Mate, is this amp 0 Ohm stable? ![]() ![]() |
Randy Bohannon ![]() Registered User ![]() Joined: 29 May 2022 Location: London Status: Offline Points: 107 |
The only high frequency driver I’ve seen that has a lower impedance than a Magnepan? :D
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4813 |
I'm not sure what magnepan is - something to do with Bakewell Tart? ![]() |
North Staffordshire |
More audiotart than bakewell Kev :D
Impedance dips below 2 ohms ~ 1khz it’s the reason the arc welder type amps exist… ![]() Edited by Randy Bohannon - 09 December 2022 at 5:24pm |
Not sure how clear the picture is, but this came in after the client had sent it elsewhere to have a 'better' fan fitted, as it was overheating. Following the repair, the client reports it's actually worse.
![]() Edited by kedwardsleisure - 17 January 2023 at 3:22pm |
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7006 |
Connected to 12V DC? ![]() ![]() ![]() |
no that's not it.
The fan is across one of the 115V primary tappings so it can be used on 230/115 Edited by kedwardsleisure - 17 January 2023 at 5:32pm |
BigSoundNorthWest ![]() Registered User ![]() ![]() Joined: 29 November 2014 Location: Manchester Status: Offline Points: 279 |
it took me a while coz it COULDNT (yet IS) be THAT stupid?
its mounted to a flat, non vented surface, as in "straight to plate" ? |
sucking on iron!!
Page <1 891011> |
