Spot the deliberate mistake |
Page <1234 11> |
login4 ![]() Old Croc ![]() Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
its a dead short?
CELTIC SUBSONIC SOUND SYSTEMS
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4813 |
Creative gets the cake, there's no 32R tap on an AC30. They should either be 2 x 8 ohm drivers in series on the 16 ohm tap or 2 16ohm drivers in parallel across the 8R tap.
Bear with me while I photoshop a slice of cake as dad hasn't cut into it yet This is the tip of an iceberg of a cock up after the amp visited a local 'vintage amp' specialist. Other faux-pas include two ECC82's where there should be two ECC83's, and an ECC83 where there should be an ECC82. The HT feed resistor should be 22R 10W on this version and it had been replaced with a 220R 6W resistor that had melted all its solder and burnt nearby wiring. The mains transformer tapping was set to 220V instead of 240V and I suspect he must've worked for Behringer as various components had been coated with hot melt glue. Edited by kedwardsleisure - 18 April 2013 at 6:37pm |
North Staffordshire |
Creative ![]() Registered User ![]() ![]() Joined: 05 February 2009 Location: Southend, Essex Status: Offline Points: 139 |
But besides that it was ok? I hope my photo of a slice of cake also will have a photo of a dollop of cream on top!
Time flies like an arrow - fruit flies like a banana!
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11696 |
Hot melt glue in a valve amp, D'OH!
Dub Specialist ![]() Old Croc ![]() Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3230 |
haha celestion green backs ?
i used to have a pair my mate give them me years ago in very old cab you know the ones with that alli silver trim stuff ![]() used to drive them with a warrior xs2500w amp not hammer them just enuff to keep up with the scoops ect to this day still dont know have i never blown them ![]() thay were still in perfect working order and i sold them on ebay to some overs seas nut brought them and got a fair bit for them too amazing ![]() |
Nitz V1505 ![]() Old Croc ![]() ![]() Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
The picture did make me chuckle.
Edited by Nitz V1505 - 19 April 2013 at 8:27am |
& THE TOPS LIKE LIGHTNING..... |
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7006 |
Would that matter since they were wired out of phase anyway? ![]() |
audiomik ![]() Old Croc ![]() ![]() Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
Re: "Would that matter since they were wired out of phase anyway?"
yes! Mik |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
Pasi ![]() Old Croc ![]() Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2730 |
But they are not on opposite polarity. Left hand connector is the + and if you turn both drivers so that connectors are at 12 o'clock, you can clearly see that + in to left driver, - out from the left driver goes to + on right driver and then - goes out to amp, and the grounding for the right hand driver is connected to this -.
Yup, the angle of the speaker does make it look wrong.
I´ve got this waiting for me in the workshop: ![]() The speakers are wired similarly - but have a nice red spot on them for the visually challenged: ![]() ![]() |
well I hope the client appreciates the difference in sound quality.
Spot the deliberate mistake(s).
a venerable Cloud VTX1500 ![]() ![]() |
Page <1234 11> |
