Spot the deliberate mistake |
Post Reply | Page <1 1920212223 33> |
Author | |||
simonp1100
Young Croc Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1110 |
Depends how good / quick you are with a de-soldering pump and where the triac is mounted in the amplifier, if its a Chevin then most of the heatsink needs to be taken apart as it's mounted near the bottom of the heatsink and if you have a spare hour then fine and it's a pain in the arse to do as well. again 6 of one & half a dozen of the other. Edited by simonp1100 - 27 April 2018 at 4:29pm |
kedwardsleisure
that relay hadn't been soldered shut, it would have been the result of the relay opening on a DC fault and arcing across the contacts 'til they melted.
North Staffordshire |
MattStolton
My first guess was self welding, but the sheer volume of material deposited looks like it has been "added to". I know the contact pads are usually some form of 2-3mm thick cylinder of metal, which is the likely source of volume of material, but that is a fecking mess! My welding often looks like that, but involves me holding the trigger down for ages to amass that much of a blob! I would have run out of gas making that.
odc04r
I figured the same, shurely too much melting there for it not to have been soldered shut! Was the mains fuse also replaced with a nail? Not the result of your average arc, the sustained current to melt that much metal must have been significant. |
ceharden
Believe it or not, I can confirm this is indeed what can happen! Just proves how much current a Crest PSU & Output stage can deliver. Probably doesn't take as much current as you might think. Also I don't believe there is any fusing on the secondary side of the transformer, only the input breaker.
Demonstrates if you go down the crowbar route, how much current the crowbar has to handle before something upstream fuses/trips. The result would still probably be a huge charred mess.
Edited by ceharden - 29 April 2018 at 10:50am |
MattStolton
On my Mig/Tig plant, as little as 20ish A at 20ish Vdc, will happily weld 1.6mm mild sheets together! 6mm to 6mm only needs 50A/60Vdc ish! More for aluminium or metals that really conduct heat away well, but don't need much to sustain an arc over a couple of mm, achieving several thousand degs C!
Off course, if you forget to turn the shield gas on, not that I ever would forget of course, the speed that a tungsten Tig electrode melts is scary. And tungsten really doesn't melt that easily....around 3400degC!
kedwardsleisure
MC2 MC1250
A picture of my copious pile of birthday presents to the first correct answer Edited by kedwardsleisure - 16 July 2018 at 12:03pm |
APW
Is that an escaped TO126 transistor I see near the bottom right? |
APW
BTW... Happy 101st!!
Edited by APW - 16 July 2018 at 12:20pm |
Earplug
Odd electrolytic cap between the boards in the middle there? Are the o/p devices BJT, or FET? |
kedwardsleisure
Bipolar. The caps are right
MattStolton
Is the second transistor up from bottom, on the left, centre pin not connected to anything? Could just be my eyesight/photo combo?
The escaped transistor, bottom right, is also of concern! |
