Spot the deliberate mistake |
Page <1 303132 |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4698 |
Mm..been a while with me and these things. The last nightclub client that used them is now a housing estate. Loose fuse clips, arcing mosfets, leaky driver transistors will all make unwanted noises on these. Earlier versions with LCR capacitors can leak electrolyte underneath them and cause the pins to arc, though ISTR its less of a crackle and more of a bang. Yours looks fairly new as it has Samwha capacitors. (all things being in perspective) |
North Staffordshire |
EmPro ![]() Registered User ![]() ![]() Joined: 26 June 2020 Status: Offline Points: 211 |
i changed the capacitors from old LCR to new samwha,remade all the solderings and added small heatsinks on the drivers as they get bloody hot in these things and make all sort of funny noise into speakers
EmPro Audio
Andylaser ![]() Registered User ![]() Joined: 16 April 2010 Location: Southampton Status: Offline Points: 262 |
Knowing those old BK amps, something very easy to fix.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
Indeed,10min if you have the parts you need,the hard part is that you need to remove the module out of the case if you need to change parts as no acces underneath because all the body case is basically heatsink for the mosfets,and that takes time
![]() ![]() Edited by EmPro - 28 May 2022 at 2:55pm |
EmPro Audio
Cloud VX-A4.
'It's been serviced regularly every 12 years.' |
After or before Christ?
EmPro Audio
jazomir ![]() Old Croc ![]() Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1675 |
Bears an uncanny resemblance to the innards of my daughter's old laptop - keyboard crud doesn't begin to describe the carnage the PC repair guy found when he opened it up.
Page <1 303132 |
