Spot the deliberate mistake |
Page <1 23456 32> |
Author | |||
djeddie ![]() Old Croc ![]() ![]() Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4113 |
I wonder who did the soldering, the blind guy or his guide dog?
_djk_ ![]() Old Croc ![]() Joined: 23 November 2004 Location: United States Status: Offline Points: 6002 |
The plaster guy, he used a trowl.
djk
odc04r ![]() Old Croc ![]() ![]() Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5483 |
Can't tell if it has actually gone bang, or is just covered in crud and a very badly installed capacitor.
mini-mad ![]() Old Croc ![]() ![]() Joined: 13 July 2012 Location: london Status: Offline Points: 6903 |
Suppose so... it did look quite ruff. ![]() |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4763 |
I'm more annoyed that the wrong capacitor was bodged in on stilts when the correct capacitors are available.
The other bodge is that there are 3 different output transistors in a row. Another half-arsed repair that has to be dealt before the current fault is traced. |
North Staffordshire |
"The other bodge is that there are 3 different output transistors in a row"
Might be OK as they are all PNP, they are usually like peas in a pod. NPN's however vary all over the map as far as gain goes.
I buy in trays of 100pcs and write the gain on each with a sharpie, it's a waste of time with the PNP's. It's very needed with the NPN's.
djk
Crown also match by Vbe as well as gain. In the UK that would be just under 2 grand for a tray of 100 transistors or $2700
Nice work it you can get it |
Geni OBY3 moving head with various faults this being one of them.
MattStolton ![]() Old Croc ![]() ![]() Joined: 04 September 2010 Location: Walthamstow Status: Offline Points: 4229 |
That chip is pissed, at least a bit legless....
Mackie SWA1501.
Been to another dealer twice who couldn't find the fault. Symptoms: Volume goes up & down on its own ![]() |
Page <1 23456 32> |
