  New Posts New Posts RSS Feed - Spot the deliberate mistake
 Post Reply Post Reply Page  <1 303132
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 7:46pm
Quote Guess what fixed the crackling sound at high volumes
Mm..been a while with me and these things. The last nightclub client that used them is now a housing estate.
Loose fuse clips, arcing mosfets, leaky driver transistors will all make unwanted noises on these. Earlier versions with LCR capacitors can leak electrolyte underneath them and cause the pins to arc, though ISTR its less of a crackle and more of a bang.
Yours looks fairly new as it has Samwha capacitors. (all things being in perspective)
North Staffordshire
EmPro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2022 at 8:55pm
i changed the capacitors from old LCR to new samwha,remade all the solderings and added small heatsinks on the drivers as they get bloody hot in these things and make all sort of funny noise into speakers LOL,no problem since.
EmPro Audio
Andylaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andylaser Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 2:39pm
Knowing those old BK amps, something very easy to fix.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2022 at 2:54pm
Indeed,10min if you have the parts you need,the hard part is that you need to remove the module out of the case if you need to change parts as no acces underneath because all the body case is basically heatsink for the mosfets,and that takes time LOLLOL
Edited by EmPro - 28 May 2022 at 2:55pm
EmPro Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2022 at 4:00pm
Cloud VX-A4.
'It's been serviced regularly every 12 years.'
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote EmPro Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2022 at 4:03pm
Originally posted by kedwardsleisure kedwardsleisure wrote:
Cloud VX-A4.
After or before Christ? LOLLOL
EmPro Audio
jazomir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazomir Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2022 at 4:53pm
Bears an uncanny resemblance to the innards of my daughter's old laptop - keyboard crud doesn't begin to describe the carnage the PC repair guy found when he opened it up.
